Windows 7: Touchpad and USB does not work after fresh install
4 Weeks Ago   #61
bbaker6212
Quote   Quote: Originally Posted by SIW2 View Post
Is there anything showing under Details> Compatible IDs
found Compatible ID's under a different section.
I2C HID Device: "ACPI\ELAN469D" Compatible Id: "ACPI\PNP0C50"
[Human Interface Devices]
[HID-compliant touch pad]
[Details: Hardware Ids]
HID\VEN_ELAN&DEV_469D&Col02
HID\ELAN469D&Col02
HID\*ELAN469D&Col02
HID\VID_04F3&UP:000D_U:0005
HID_DEVICE_UP:000D_U:0005
HID_DEVICE
[Details: Compatible Ids:]
<none>
[Matching device Id]
[Configuration Id]
input.inf:HID_DEVICE_UP:000D_U:0005,HID_Raw_Inst.NT
[I2C HID Device]
[Details: Hardware Ids:]
ACPI\VEN_ELAN&DEV_469D
ACPI\ELAN469D
*ELAN469D
ACPI\PNP0C50
PNP0C50
[Inf name]
hidi2c.inf
[Driver version]
10.0.16299.15
[Configuration Id]
hidi2c.inf:ACPI\PNP0C50,hidi2c_Device.NT
[Driver stack]
\Driver\mshidkmdf
\Driver\hidi2c
\Driver\ACPI
[Microsoft Input Configuration Device]
HID\VEN_ELAN&DEV_469D&Col03
HID\ELAN469D&Col03
HID\*ELAN469D&Col03
HID\VID_04F3&UP:000D_U:000E
HID_DEVICE_UP:000D_U:000E
HID_DEVICE
<none>
[Mice and other pointing devices]
[HID-compliant-mouse]
<same as the Microsoft Input Configuration Device>
4 Weeks Ago   #62
SIW2
Vista x64 / 7 X64
4 Weeks Ago   #63
bbaker6212
Thanks I'll try it. Note the pic below. None of my HID devices look correct or what they were when booted in the PE.
4 Weeks Ago   #64
bbaker6212
I ran the dpinst.exe as administrator and rebooted but nothing is different.
Is there something special I need to do? disable the existing HID devices first?
Btw, found an older Lenovo Yoga Win8 downgrading to Win7 with the same problem with touchpad with same (Compatible ID see red below): Downgrading from Win 8 and making I2C touchpad work with Windows 7 - Lenovo Community
01-21-2015 10:17 AM
Lenovo Yoga 3 Pro-1370, Intel Core M (CPU: 5Y70)
I have downgraded Lenovo Yoga 3 Pro-1370 to Windows 7-64 and its touchpad (Synaptics) is not detected by Windows at all (and not shown in Device Manager). As far as I understand, the touchpad is connected via I2C interface (not USB or PS2). I2C is handled by Windows 8 at a systemic level and very differently from Windows 7.
Lenovo does not support Windows 7 on Yoga 3 and does not provide Windows 7 drivers.
I tried different Win7 Synaptics drivers from other Lenovo models as well as generic drivers from Synaptics. No success.
What is the likelihood of making the touchpad to work with Windows 7? Will OEM drivers from other manufactures possibly work?
For Windows 8, the Yoga 3 chipset includes ‘Intel Serial I/O Driver’ which (I guess) takes care of I2C.
In Windows 8 Device Manager, there are 3 devices related to the touchpad
Touchpad itself
HID\VEN_SYNA&DEV_2B22&Col01
HID\SYNA2B22&Col01
HID\*SYNA2B22&Col01
HID_DEVICE_SYSTEM_MOUSE
HID_DEVICE_UP:0001_U:0002
HID_DEVICE
Driver: Synaptics
Intel(R) Serial IO I2C Host Controller - 9CE1
Driver: 'iaLPSS_I2C.sys' (Intel)
ACPI\VEN_INT&DEV_3432&REV_0003
ACPI\INT3432
*INT3432
Enumerator: ACPI
oem7.inf
I2C HID Device (on Intel(R) Serial IO I2C Host Controller - 9CE1)
ACPI\VEN_SYNA&DEV_2B22
ACPI\SYNA2B22
*SYNA2B22
Compatible Ids: ACPI\PNP0C50
HID\SYNA2B22&Col01\5&f4a3470&0&0000
HID\SYNA2B22&Col02\5&f4a3470&0&0001
Parent: ACPI\INT3432\3&11583659&0
Driver: Microsoft
Enumerator: ACPI
hidi2c.inf
4 Weeks Ago   #65
bbaker6212
Boot this and check for the device id in device manager
16299_x64-v2.iso
Btw @SIW2 this is a cool live-boot disk. Where'd it come from? Know how I can put my WiFi drivers on it (in it)?
4 Weeks Ago   #66
SIW2
Vista x64 / 7 X64
Yes.
1.Copy boot.wim from your usb stick sources folder to your hard drive.
2.Mount boot.wim using dism++.
3.Add the drivers.
4.Save the image.
5.Unmount the image.
Copy the updated boot.wim into the sources folder on your usb stick.
You are best using the win10 wifi drivers from your manufacturers website.
screenshots for using dism++
In addition, before saving the image ( step 4 above) I suggest:
Copy the pecmd.ini file from this zip SYSTEM32-new-pecmd-ini.zip into the mounted boot.wim Windows\System32 to replace the existing one.
Then place the two files from this zip Root-of-USB-stick.zip on the root of the usb stick.
Create a folder on the root of your usb stick called Uprograms.
MOVE these folders from your mounted boot.wim Program Files to Uprograms folder on the usb stick.
MOVE this folder from the mounted boot.wim Program Files (x86) to Uprograms folder on your usb stick
Now save the Image, then unmount the image.
4 Weeks Ago   #67
bbaker6212
Quote   Quote: Originally Posted by bbaker6212 View Post
@SIW2 any idea about the touchpad driver I commented on above?
4 Weeks Ago   #68
SIW2
Vista x64 / 7 X64
Your usb stick layout will look something like this:
Inside the Uprograms folder will be the folders you just moved ( similar to this)
4 Weeks Ago   #69
SIW2
Vista x64 / 7 X64
You could try running the setup.exe instead of dpinst. And/or you could try uninstalling the current drivers from device manager before running setup.exe. And/or you can try installing the drivers using dism++.
3 Weeks Ago   #70
bbaker6212
Yes.
1.Copy boot.wim...
...Now save the Image, then unmount the image.
Thanks for that. I did it all and the WiFi driver loads without error in the device manager.
And it sees my router but when I type in my password and click connect it doesn't do anything.
Is some part of the WLAN sofware missing from this live-USB?
Fresh install: Touchpad pointer lost after sleep. randomly.
Guys I've been using this little Thinkpad x120e for years: I can't find a replacement that does as much as well :geek:. I just did a fresh install of win7 x64 home premium on a new samsung 840 pro ssd. it all works swell. except today: doing absolutely nothing unusual, running on battery, I...
Hardware & Devices
Touchpad often doesn't work
Hello everyone. Recently, I did a clean install of Windows 7 Home Premium on my MSI GE600. At first, the touchpad behaved the way it should. But now, it is not even detected. I rebooted the laptop and it worked again. Most of the time it doesn´t work though. I have installed the Elantech...
Hardware & Devices
Why do not work my laptop touchpad?
Hello Every one, have a nice day! please help to provide a solution by the given the answer of the question- Why do not work my laptop touch pad? I have attached a file for your info. thanks
Hardware & Devices
Hp Envy 14 After a fresh re-install Internet doesnt work.
Hey guy's this has been bugging the heck out of me! I re-installed my copy of windows 7 Home Premium, went to HP's website and installed the drivers i thought were needed. My network controller still displays the little yellow triangle. Wireless doesnt work at all, and wired just says "internet...
Drivers
Touchpad doesn't work!?
Hello. I've got a VAIO VGN FE11M. My touchpad doesn't work since yesterday. It's really weird because I checked it in my device manager and it says that everything is okay. Now I've reinstalled my whole computer because I thought that it doesn't work because of the drivers. It still doesn't...
Hardware & Devices
Twitter Facebook
