#31
21.20.16.4508 supports kabylake
Support For B250M GAMING PRO | Motherboard - The world leader in motherboard design | MSI Global
SIW2, I know that the graphics and chipset is one of the missing drivers that is why I want to get it done.
PCI memory controller or PCI device is the M.2 MVMe driver and you have them all.
Bbaker, do you know how to get the hardware ID from a device on Device manager?
21.20.16.4508 is a beta driver.
Gigabyte also shows 21.20.16.4550 http://download.gigabyte.us/FileList..._200series.zip
After all set I would run Intel driver update utility (Intel® Driver & Support Assistant)
https://downloadmirror.intel.com/284...0Installer.exe
yes.
btw, here is a list of supposedly all the drivers identified on my notebook via DriverIdentifier scan:
LENOVO Lenovo Ideapad 330S (81F4) drivers - Scan Result ANONYMOUS -
In that case, try the 21.20.16.4550 that mega already linked. It says it is compatible with skylake and kabylake.
GA-B250M-Gaming 3 (rev. 1.0) | Motherboard - GIGABYTE Global
same result with this one, no matter if I use the original .inf or the one Mega attached.
I'm pretty sure the problem is my display adapter hardware device id DEV_5917 is not in that .inf file. A potential solution to mod the inf file here: Way to make Intel UHD 620 graphics driver to works in windows 7 (no crash in video play back, 3D function normally) - Video Driver Releases & Discussion - Tech|Inferno Forums
I've seen on the Lenovo Ideapad 330S specs that it can have AMD or Intel internal graphics?
Are you sure yours doesn't have AMD graphics?
On post #27 it says it has an Xeon CPU that I believe it's not true.
