Windows 7: 8GB Ram no detect in 32bit & in 64bit it not running in its full speed
22 Feb 2020   #11
truemate
Windows 7 Ultimate x64 & Win10 x64bit LTSC
Plz reply fast...as the return policy time will end...and I can't return this RAM back...money wasted
22 Feb 2020   #12
iko22
Windows 7 x64, Vista x64, 8.1 smartphone
You really need RAM with matched frequencies and latency timings. If the RAM has XMP profiles, then all the better.
If you still can return one of the RAMs in its original packaging, then I'd return the Kingston model.
22 Feb 2020   #13
truemate
This no one told me before...that latency timing need to be matched too...all bloody sales guy in form of technician..they just want to sell their product..
Now when I come to know abt this issue they r like tight lip...half knowledge/brain is dangerous than empty brain.
So iko22, it's no way to tweak their settings to make them run in same latency timings to get 800mhz.
22 Feb 2020   #14
iko22
Quote   Quote: Originally Posted by truemate View Post
Short answer, is yes you can tweak RAM sticks, but not those RAM sticks.
Longer answer:
Some people have quite successfully tweaked their RAM specifications in their computer rig. They buy special RAM with effective heat spreaders, on RAM models that have reputation for being able to tweak.
Your basic RAM (the Kingston model) is not designed for being used under such conditions. If you try change parameters in BIOS, I suspect the RAM will just fall over, and the operating system will fail.
If you change any RAM parameters, then always run MEMTEST afterwards, to test the reliability of your changes.
22 Feb 2020   #15
truemate
So this kingston is like I can't do anything to it..
But what abt Corsair can it will be adjust thru parameters to make it adjust with kingston timings ?
22 Feb 2020   #16
iko22
Yes, in a nutshell, I think you are right.
But, it is not the brand "Kingston" that is the problem, it is because you have only invested in their budget memory sticks. If you had 8GB of Kingston model RAM, then you'd be okay, as you would not need to match any parameters manually.
The "corsair" model are better grade of RAM. Again, it is not the brand, it is because you have invested in better grade RAM sticks. BUT they do not match the "Kingston" for parameters. Therefore, you need to manually set the parameters for both RAM sticks, in BIOS, to match the values of the "Kingston". Then run MEMTEST to double check the RAM reliability.
22 Feb 2020   #17
Barman58
Windows 10 Pro x64 1909 - 18363.657 XP/Vista/Win7/Win8.1 in VM for testing
As with anything if your motherboard allows you to adjust your RAM parameters, you can adjust the fasted (best) to match the worst, there is no point in trying to set the parameters of the worst RAM to match the Best as it is incapable of achieving the speed of the best.
The other issue is that in a mixed RAM scenario, the system should automatically match the highest performance RAM to the Lower performance RAM, this is to prevent issues when running
If you overclocked the lower rated RAM to match the higher you might have an improvement overall for a short time - until the RAM failed.
You should only buy RAM from specialists - Online is usually best as they sell more so prices per unit are lower. always try to buy RAM in the size you require in total or if you upgrade ensure the additional RAM matches the Older
22 Feb 2020   #18
iko22
The OP could adjust RAM parameters to underclock the better RAM to match the lower performing RAM.
While this is not a good idea when buying RAM, given that is what is now available to you, then that is the best and most reliable match.
08 Mar 2020   #19
truemate
sorry friends for the late reply....
actually u all right,,, thats not possible to match this budget kingstone ram with corsair one.. i try every way.. even changed it timings but...nope... sys was getting little slow... as it jumping back to that 1300mhz speed...
So i decided to give it back...
Now running corsair in XMP mode to 1600mhz 9-9-9-24
and yea i even formatted my pc and now on 64bit..
i really see some performance by jumping to 64bit and running ram (xmp) in max freq :)
actually it performing better compare to that 2 RAM stick formula of diff Timings
Need for Speed™ Most Wanted Running in Windows 7 32bit
Need for Speed™ Most Wanted Become the Most Notorious Wake up to the smell of burnt asphalt as the thrill of illicit street racing permeates the air. From the makers of the hit Need for Speed™ Underground series, Need for Speed™ Most Wanted challenges players to become the most notorious...
Gaming
got new Ram... not sure if its running at full speed...
ok i got new ram today Vengeance® — 16GB Dual Channel DDR3 Memory Kit (CMZ16GX3M4A1600C9B) Memory Type: ...
General Discussion
How to know if CPU is running at full speed ?
Hey guys, I'm a 3D artist, and I'm currently rendering out a whole load of frames. I'm using a reasonable, Sony Vaio laptop for the task, which has an Intel i7-720QM, however I'd like to know what CPU speed it's currently operating at. I know that it says it runs at 1.6Ghz as standard but then...
Hardware & Devices
How to detect if a Win7 install DVD contains 32bit or 64bit version?
We have bought some month ago 32bit and 64bit versions of Win7. From one of them we burned a backup DVD. Now we need to re-install Win7 on a computer but we did not found the original DVDs. Fortunately we have the backup DVD available. Is there a way to find out if it contains the 32 bit...
General Discussion
HIGH speed USB hub running at FULL speed.H
after dealing with PCI usb hub. i went and got external usb hubs and yes it worked on windows 7, but only FULL speed, my cam went from fast to laggie, iphone connect to usb hub had a message " it can perform faster if connect to a high speed port" , i check under device manager and it says " the...
Hardware & Devices
Twitter Facebook
