Windows 7: Needs advice regarding pc parts
09 Dec 2009   #11
sergiogarcia9
Now, what video card should i choose? I think that is the one thing that mind ruin my budget
09 Dec 2009   #12
sergiogarcia9
Or perhaps i should choose another processor and/or case?
09 Dec 2009   #13
ignatzatsonic
Yeah, forgot about that. Looks like your budget is shot if you want a "gamer" video card.
I don't game and spent under $50. You can spend $400 and up if you want, depending on how obsessed you are with the cutting edge. It will be cutting edge for a month or two. High RPM fans, heat, noise, etc. You tolerate that if you game.
You should toss in maybe $30 to $50 for some thermal compound (Arctic Silver typically) and a couple of good chassis fans.
If you will be gaming significantly on a high powered video card, you may run a little on the hot side, so your fans may need to be spin faster--otherwise you could go low noise low RPM on fans. You should figure one exhaust fan in the rear and quite possibly a similar fan on the front side.
If you don't overclock, you can probably get away with the standard AMD processor heatsink--whatever that is. I'm not even sure they come with one like Intel.
09 Dec 2009   #14
sergiogarcia9
Maybe i should stick to graphics editing instead of gaming, since i already got a 360 which i can use for that
09 Dec 2009   #15
ignatzatsonic
Well, yeah on the other CPU and case. I figured from your comments that you were locked in for reasons of your own, which is fine.
If not, then Intel CPU is the choice. For your budget look at Newegg for Intel "i5" or "i7" processors that are in the 700, 800, or 900 number series. These would be "socket 1156" or "socket 1366". These 700 and 800s are only a couple of months old and are powerhouses.
I think they all use DDR3.
Case is personal preference. Try to buy one WITHOUT a power supply if you can. Standard power supplies can be shaky. Good case brands generally: Antec, Coolermaster. You will need ATX or micro ATX, depending on your mobo choice.
09 Dec 2009   #16
sergiogarcia9
I have looked at the i5 but it seems expensive. About 220 USD And i hear that the mobo's for it is expensive as well
09 Dec 2009   #17
ignatzatsonic
i5 motherboards are cheaper than i7. Look at Newegg. You can get i5 motherboards down to $100.
Look at Asus, Intel, Gigabyte, MSI. You don't need a $200 board if you won't overclock.
i3 is another choice. They are slower and may not yet be out?? The i3 processors are in the 500 number series.
09 Dec 2009   #18
sergiogarcia9
I've had a look online.
Intel Core i5 Lynnfield 2.66 = 1.273,00 DKK (250 USD)
Intel DP55WG mATX Socket1156 NIC Bulk = 635 DDK (125 USD)
I might go for that
09 Dec 2009   #19
Xzaviar
MOBO and Proc
MOBO: Gigabyte GA-M790X-UD4P This MOBO will take DDR3 and it seams to make a fair difference.
Proc: AMD Phenom XII 550 Black Edition.
With this combination you can unlock the four cores in the processor. This will give you a 4 core 3.1Ghz proc for about $100.00 and $100.00 for the MOBO.
I recommend this because the money savings over buying a 3 or 4 core proc can be put into other components.
09 Dec 2009   #20
ignatzatsonic
I don't know anything about Denmark prices.
In the USA:
Lynnfield 750, i5, socket 1156, quad core; 200
Case: 60
PSU: 70
6 gigs DDR 3 160
Mobo 150
Midrange video card 150
Fans, etc: 40
That is 830.
Add hard drives.
Shave off RAM, CPU, video card as needed to meet your budget.
Looking for Advice - Parts list for Water-Cooling
Hi folks - I have a couple water-cooling questions - thank you for whatever you care to share! Case - HAF X CPU - 980X Fans - Noctua NF-F12 WC Loop for CPU only My priorities and expectations for the WC loop:
PC Custom Builds and Overclocking
Needing new parts and advice
I have an older HP desktop that I've upgraded the parts over time. I want to replace the motherboard and processor and get a new video card as well but the video card can come later. I want to do this as inexpensive as possible I know it's going to be a tedious job. I need to know what parts I...
Hardware & Devices
Need some advice on chosen parts for my new build
Hi there, it's been a while :D I need avice on the parts i've chosen for my new build. Will mainly be used for gaming, Internet browsing, work and music. Intel CPU Core i5 3470 Quad Core Processor - Retail - BX80637I53470 - Scan.co.uk Corsair Memory Dominator 8GB DDR3 1600 MHz CAS 9 DHX...
Need advice on a couple computer parts
So I'm basically rebuilding my computer and I need advice on a couple motherboards and brands on memory. The two motherboards I'm choosing from are these: Newegg.com - ASUS P8Z77-V LK LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS Newegg.com - ASUS...
Hardware & Devices
New Build with some recycled parts... Questions/Advice! Please
current computer: HP PAVILION A6347C It's specs are as follows 16X DVD(+/-)R/RW 12X RAM (+/-)R DL LightScribe SATA drive Windows 7 Ultimate 64Bit AMD ATHLON64 X2 DUAL CORE 5600+ 2.8GHZ
Twitter Facebook
