Windows 7: Needs advice regarding pc parts
10 Dec 2009   #31
nate42nd
Windows 7 Professional x64
Quote   Quote: Originally Posted by sergiogarcia9 View Post
I will go with the 8 gb then I will buy the i5 though, as that is really my favorite CPU :)
Good choice! Look into the new Gigabyte boards that have USB 3 and SATA 3 and 3 times the power to the USB ports! They are the latest stuff!
http://www.newegg.com/Product/Produc...82E16813128409
10 Dec 2009   #32
sergiogarcia9
So... PSU... What should i get?
10 Dec 2009   #33
nate42nd
This would be one of the best. They cost a little more but you will NEVER regret it.
Modular....and they come in higher (and lower) wattages if you so desire.
Newegg.com - CORSAIR CMPSU-650HX 650W ATX12V v2.2 / EPS12V 2.91 SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply - Power Supplies
10 Dec 2009   #34
sergiogarcia9
Looked at the prices for DDR3 ram... Not cheap, i will have to go with 4 GB to start with, i think
10 Dec 2009   #35
sergiogarcia9
I would have to pay like 400 USD for 8 GB DDR3 Ram
10 Dec 2009   #36
nate42nd
4 GB is a good start. I went with 8 GB and ended up moving back to 4 GB because I was no coming close to using even 4 GB.
Look around at the prices. DDR2 WAS a lot cheaper 5-6 months ago, but today they are very close and you're getting quite a bit more speed and efficiency.
10 Dec 2009   #37
sergiogarcia9
NZXT Tempest Midi Tower Black
Corsair TW3X4G1600C9DHX, 2x2048mb
Intel Core i5 Lynnfield 2.66 ghz
Intel DP55WG mATX Socket1156 NIC Bulk
500 GB HDD
Corsair TX650W
Samsung 250GB SATA2 7200Rpm
PRICE (Without DVD drive) = 865 USD (4386 DKK)
That is a tad more expensive than i want it to be
10 Dec 2009   #38
ignatzatsonic
I don't see a video card in that list.
Are you locked into that case? It is 110 here in the US. You can certainly knock 30 or 40 off that easily.
Consider these, all around $60 to $70
Antec 300; It has front and rear 120 MM fans and space for plenty of drives.
Coolermaster Centurion 534 or Centurion 590;
Gigabyte Triton 180
You have modest power supply requirements--400 to 500 watts is plenty.
These are good units and most are "80 plus certified", which is of some benefit.
Antec Earthwatts EA500 500W Continuous Power Supply - Retail
CORSAIR CMPSU-450VX 450W ATX12V V2.2 80 PLUS Certified Active PFC Retail
Seasonic M12II 430 watt modular
Seasonic SS-500ET Bronze 500W ATX12V v2.31 80 PLUS BRONZE Certified Active PFC Power Supply - OEM
CORSAIR CMPSU-400CX 400W ATX12V V2.2 80 PLUS Certified Compatible with Core i7 Power Supply - Retail
FSP Group SAGA+ 450R 450W ATX12V Power Supply - Retail
10 Dec 2009   #39
sergiogarcia9
I think i've found it with help from DarkNovaGamer and Mr Grim
CPU:
AMD Phenom II X2 545 3.0GHz 80W (Box) 568,00 DKK
Link: Proshop.dk ApS - AMD Phenom II X2 545 3.0GHz 80W (Box) - HDX545WFGIBOX - Pris DKK 568,00 - Processorer fra AMD
Motherboard:
ASUS M4A77TD PRO AMD770 DDR3 EPU ATX 611,00 DKK
Link: Proshop.dk ApS - ASUS M4A77TD PRO AMD770 DDR3 EPU ATX - 90-MIB9S0-G0EAY00Z - Pris DKK 611,00 - Bundkort fra ASUS
GFX Card:
ASUS GeForce GTS250 - 1,0 GB GDDR3 256bit 917.00 DKK
Proshop.dk ApS - ASUS GeForce GTS250 - 1,0 GB GDDR3 256bit - ENGTS250 DK/DI/1GD3 - Pris DKK 917,00 - Grafikkort - PCI Express fra ASUS
RAM:
Corsair TW3X4G1600C9DHX, 2x2048mb 705 DKK
HDD:
Samsung 250GB SATA2 7200Rpm 283,00 DKK
PSU:
Seasonic S12 II SS-500GB, 500W PSU 688.00 DKK
Case:
NZXT Tempest Midi Tower Black 745 DKK
ALL TOGETHER = 4517 DKK /974 AUD / 892 USD
At least i stayed under 1000 USD
10 Dec 2009   #40
nate42nd
I would disagree with that choice or CPU and motherboard, but I suppose we all have our preferences.
The i5 would be MUCH better.
But it looks good, good luck on the build, you will be more than happy I'm sure.
Looking for Advice - Parts list for Water-Cooling
Hi folks - I have a couple water-cooling questions - thank you for whatever you care to share! Case - HAF X CPU - 980X Fans - Noctua NF-F12 WC Loop for CPU only My priorities and expectations for the WC loop:
PC Custom Builds and Overclocking
Needing new parts and advice
I have an older HP desktop that I've upgraded the parts over time. I want to replace the motherboard and processor and get a new video card as well but the video card can come later. I want to do this as inexpensive as possible I know it's going to be a tedious job. I need to know what parts I...
Hardware & Devices
Need some advice on chosen parts for my new build
Hi there, it's been a while :D I need avice on the parts i've chosen for my new build. Will mainly be used for gaming, Internet browsing, work and music. Intel CPU Core i5 3470 Quad Core Processor - Retail - BX80637I53470 - Scan.co.uk Corsair Memory Dominator 8GB DDR3 1600 MHz CAS 9 DHX...
Need advice on a couple computer parts
So I'm basically rebuilding my computer and I need advice on a couple motherboards and brands on memory. The two motherboards I'm choosing from are these: Newegg.com - ASUS P8Z77-V LK LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS Newegg.com - ASUS...
Hardware & Devices
New Build with some recycled parts... Questions/Advice! Please
current computer: HP PAVILION A6347C It's specs are as follows 16X DVD(+/-)R/RW 12X RAM (+/-)R DL LightScribe SATA drive Windows 7 Ultimate 64Bit AMD ATHLON64 X2 DUAL CORE 5600+ 2.8GHZ
Twitter Facebook
