32 bit -to- 64 bit system and OS
Edited: Please start here at link right below if you open this thread as it got messed and confused. Clarified it alittle better to what i was exactly trying to say and get thoughts on.
Thread is solved / ended.
I will have the thread marked as solved and deleted just so no more misunderstands or posts. Thxs
OK.. As some of you know here. Im pretty good and skilled with all this computer / high tech crap but..
Trying to get some insight from you guys and trying to figure something out and a way to do this so..
Basically asking for a friend of mine trying to set something up for her and get it to work right and cheap.
So basically she has a 32bit vista home prem system and we trying to maybe make hers to win7 home prem but... 64bit upgrade. (disks that i have). was going to try and upgrade hers for free with my disks.
So as i know and you guys know can only upgrade from like home prem to home prem, or ultimate to ultimate etc etc..
but now hers is a 32bit system. my disks are 64 bit win7 home prem.
So thing is what would be easier and better to do or i should say how to get it to be able to be upgraded to the 64bit version. What would be easier and more cost effective to switch hers to 64 bit and be able to then use upgrade to win7 64 bit ??
What would we have to do and how much cash to switch hers from 32bit to 64bit system ??
Think that would be cheaper then to just do a 32 bit win 7 anytime upgrade ??
Plus as because we are trying to get hers to a 64 bit system anyways instead of 32. What do you all think would be better anyways and/or best way to do it in total. whether we keep the same 32 bit to a win7 32bit disk or anytime upgrade or switchin to 64 system and win7 OS.
Any idea's, examples, input etc etc. All is welcome. different ideas and such ??
Hope that made sense..lol
