HP Pavilion DV2000 display problem
  1. Posts : 17,545
    Windows 10 Pro x64 EN-GB
    Sorry.
    The screen is captured raw, as GPU produces it. As you can see, there's no extra distortion on your screenshot so it's quite clear the problem is the display.
    Changing the laptop display costs easily more than a new laptop. IMO, you have two choices: live with that or get a new laptop, especi8ally when you have other problems with it.
    Kari
  2. Posts : 11,408
    ME/XP/Vista/Win7
       #12
    You could try with a external screen & post back.
  3. Posts : 92
    hmm hmm sounds strange. I tried external display was going fine i rebooted 2-3 times. Then i disconnected it. And started pc again it was working fine very clear no lines. Used it for 30min appx without problem. Then I start watching videos on youtube. When I switch it to full screen, my lapi got stuck. now again those lines on lcd .
  4. Posts : 92
       #14
    I doubt if I'd LCD problem, why my lapi get stuck?
  5. Posts : 11,408
    ME/XP/Vista/Win7
       #15
    Sorry to here that.
    Looks like a New Notebook.
  6. Posts : 983
    10 x64 | 7 x64
       #16
    My daughters HP DV6000 series laptop had a similar problem.
    The lcd had lines and it flickers. However it had a function key to use the vga port and we connected a spare monitor. The machine is out of warrantee and it would cost more then it's worth to fix. So now it's set up as a desktop.
  7. Posts : 92
       #17
    You make me laugh at the end, that's what my bro said to me that time for u to use ur lapi as desktop. Thanks for advice but I'll once head for HP service center.
  8. Posts : 17,545
       #18
    Saeen, it would be interesting to hear what HP says. Keep us posted.
    Kari
  9. Posts : 92
       #19
    I think that problem is not of LCD cause now in safe mode, there is no problem but when starting in normal mode, it create problems. Anyways, will go to HP care.
  10. Posts : 1
    Windows Home Premium 32bit.
       #20
    hi saeen
    Hi saeen, this is ramesh, same problem i also getting now... i dont no what to do... i went to my country HP service center it's called by "DMS" they are the one main head delares in my country but that people are told me it will take more time i mean more than a week to reparia it and i dont like to give any other laptop reparia center... coz its HP so i thought HP service center will help me to do it but not her vry bad,,, service... still i cant get repaire it... have you repaire it? is it working you well now... ? please reply me please please please
    thank you,
    ramesh
