Problem with usb hard drive
  1. Posts : 3
    I have a backup drive a wd 5000aavs and my laptop stopped recognizing it today after i formatted the drive with acronis disk director. This also happened with my 16gb san disk flash drive about a month ago. I have uninstalled all drivers for it and let if reinstall still not coming up with the drive just the usd-to-sata adapter. I have a backup pc its running windows xp and it is recognizing everything perfectly. What can i do about my tablet laptop?
  2. Posts : 6,243
    try a different usb port if you have one , there seems to be a bit of a problem lately of usb ports dying or check if your usb-sata adaptor is at fault
  3. Posts : 3
    I just tried all 3 and there was no difference . The adapter is working fine for all my other device(all my ipods, pda and even flash drives). Thanks for the help
  4. Posts : 6,243
    are you letting windows find the driver? or are you installing from the supplied disc?
  5. Posts : 3
    I have been letting windows find the driver as it did before.
  6. Posts : 6,243
    right, ok then try loading the drivers off the disc ,but run them in vista compatability mode see if that will do the trick
