Modem driver problem, help?
  1. Posts : 2
    I can't find a windows 7 driver for my motorola sb5100 modem. I tried using the vista one but i can't get it to work. I read in another post that the vista one should work, it extracts the files to my desktop but they don't do anything.Anyone have any ideas?
  2. Posts : 10,200
    change from usb to ethernet connection
  3. Posts : 2
    Is there a way to do it by USB?
  4. Posts : 233
    Windows 7 Professional 64-bit
    Where did you get the drivers? Did you check the motorola website?
