First time building my own PC. (need help)
Page 2 of 2 FirstFirst 12
  1. Posts : 13,354
    Windows 7 Professional x64
    A mobile processor is a processor for use in netbooks. It uses very little power and not much heat.
  2. Posts : 662
    Windows 7 Home Premium x64, Mac OS X 10.6.2 x64
       #12
    Ok well im going with the E6300
    Now the specs
    System Manufacturer/Model Number - Me
    OS - Windows 7 Home Premium x64
    CPU - Intel Pentium E6300 @ 2.8 GHz
    Motherboard - Asus ATX P5P43TD Pro
    Memory - 4 GB DDR3 1333 MHz (2x2GB)
    Graphics Card - ATI Radeon HD 4650 1GB DDR2
    Sound Card - Integrated
    Monitor - Samsung TV (for now)
    Screen Resolution - 1920x1080
    Keyboard - Dell
    Mouse - Dell
    PSU - BFG - 450-Watt ATX
    Case - Thermaltake ATK Soprano Mid-Tower Case - Black
    Cooling - Generic Fan that i had laying around
    Hard Drives - Seagate 500 GB 3.5" 7200 RPM for Desktops
    After a few alterations i brought it down to 580$. Is this good for that price?
  3. Posts : 2,606
    Windows 7 Pro X64 SP1
    $580 doesn't seem too bad, particularly if you're dealing with Best Buy. (Sorry, but I think that a lot of their PC component prices are atrocious. Not all and not always, but I still prefer to do business with Newegg.)
    You may want to price out an AMD based system. For example:
    Asus M4A77TD (Socket AM3, DDR3, $85 [$10 rebate available]):
    Newegg.com - ASUS M4A77TD AM3 AMD 770 ATX AMD Motherboard - AMD Motherboards
    AMD Athlon II X4 630 (2.8 GHz, quad core, $100):
    Newegg.com - AMD Athlon II X4 630 Propus 2.8GHz 4 x 512KB L2 Cache Socket AM3 95W Quad-Core Processor - Processors - Desktops
    In this price range, AMD is more than competitive with Intel's offerings. (I'm using Intel at the moment, but I've had a couple of Athlon64 systems, that were better than Intel's offerings at the time.)
  4. Posts : 662
       #14
    Yea I know AMD has better specs for the price usually, but I want an Intel for better Hackintosh compatibility, because I plan on installing 10.6.2 on this rig too.
  5. Posts : 7,878
    Yeah, if you want to go the Hackintosh route, you gotta stick with Intel. And it's usually not a bad choice as they have the edge in processing power and have since the release of the Core 2 Duo.
    I screwed around a bit with setting up my box as a Hackintosh using the EFI-x module. In the end, I found that I really didn't like OSX all that much and have removed all of it. Some would say it was a waste of money (about $360 for the module and my copy of OSX), but I think it saved me from purchasing a MAC anytime soon. I did get a macbook pro for awhile at work to play with, but my experience with that wasn't all that much better either. Guess the whole MAC OSX thing is just not me.
  6. Posts : 662
       #16
    I planned this rig with OSx86 in mind. All of it can get a full support with a kext I found. I am going to use the SnowOSXUniFlash, that always works. I just needed a good hackintosh after trying it on my laptop, which is probobly the most imcompatible laptop for a hackintosh. Plus I wanted a more powerful Computer. I plan on keeping the accounts synced and mabye have a private TV session always open so I can connect to it at any time.
  7. Posts : 7,878
    Well, best of luck to you. Some people really love it. For me, I considered the OSx86 project...but I wasn't interested in having to use hacked copies of the OSX installer. That's the reason that I went the EFI-x route....it allowed me to use a retail off the copy of the Leopard installer. I just don't trust hacked copies of the OS...since I fear that something nefarious could be installed without my knowing.
  8. Posts : 662
       #18
    Well part of the reason im using the Universal one, was I helped with it a bit, so i know pretty much whats in it.
    My simple philosophy is that if it can be updated through Apple Software Update, then its fine, because when you update OSX itself (from 10.6.1 to 10.6.2) it removes anything that OSX seems to be harmful to the OS. I tricked OSX into thinking it was 10.6.1 just to run the 10.6.2 update, and it worked.
