Windows 7: Sound didnt return after using DVI-to-HDMI cable
07 Apr 2010   #1
Thorsen
Win7 Home Premium 64x
My friend has a computer that I helped build. I was testing to see if using a DVI cable would increase his graphics. It is DVI to HDMI and a message appeared that said sound was no going to go through the DVI.
Well, we switched back to VGA and he has no sound. Is there an option to set it back to not using HDMI for sound?
Thanks in advance
07 Apr 2010   #2
stormy13
Microsoft MVP
Win 7 Ultimate x64
If you haven't start with checking the Windows Sounds playback settings, and make sure the sound card is set as the default device.
07 Apr 2010   #3
Thorsen
ok so this is what is happening.
Sound out works through fiber optic
Sound out works through USB to logitech headphones.
Sound on HDTV monitor works from HDMI from TV
Sound on HDTV monitor does not work from computer.
I am going to try uninstall and reinstall the drivers
07 Apr 2010   #4
Thorsen
Well first system restore didn't go far enough. Reverted to yesterday's System restore and its fixed. Still dont know what went wrong. The comp said audio now goes through HDMI? and then was not able to change it back? I dont know, but I am good now.
bundling HDMI cable together with USB 2.0 cable will be interferences?
If I tape together tightly HDMI and USB cables for a 15 foot run, will they cause any interference? I know they are digital signals so I think should not. But doing this does cause a herring bone interference with analog vga cable.
Hardware & Devices
Should I use an HDMI or HDMI-DVI cable to connect to my monitor?
I have a video card with both a DVI and an HDMI output and a monitor with only an HDMI input. Should I connect my monitor to my PC with an HDMI cable or with a DVI - HDMI cable?
Graphic Cards
NO SOUND TROUGH HDMI ON ACER AX3400-U3032 and No HDMI Icon in sound se
Had to replace motherboard from authorized acer parts dealer now I get no sound through HDMI port. I did through the original board until it got fried by electrical surge. Can any one help or send me a picture of the inside the same model to make sure all jumpers on the motherboard are in the...
No sound to HiFi speakers when HDMI Cable Connected
Hi I have connect my laptop using an HDMI cable to my TV. And from my tv I have connected my two HiFi speakers. When the TV is on an AV channel I have sound coming from the TV and HiFi speakers but when I switch it to the HDMI source channel, sound only comes from the TV and not HiFi speakers....
No sound through the HDMI cable
I have a TV with HDMI and when possessed Vista both the sound and image were transmitted by cable, put the 7 and only the image is transmitted on television, the sound driver is installed and supports HDMI transmission is the same as used in Vista. How can you fix the problem? I did not know...
