null port for file conversion
  1. Posts : 4
    I've installed Quick Books 10 on my PC. In conjunction I've installed a NUL port in Devices called QuickBooks PDF Converter 3.0. The PDF converter allows you to convert a Quick Books file to a PDF. Attached is a small .bmp (hopefully you can read it) showing the configuration.
    With XP Pro, I didn't have to do this conversion. I just did a 'save as' and made referenced a PDF extension.
    THE PROBLEM: Everytime I reboot, The NUL port goes away and I have to add it again under Devices. Kinda a pain.
    Thoughts?
    Paul
    Parker, CO
    Attached Thumbnails Attached Thumbnails null port for file conversion-rsz_quickbookssnapshot.bmp.jpg
  2. Posts : 4
    Great idea, I think I'll try that.
  3. Posts : 4
    That didn't work
  4. Posts : 1
    NUL Port vanishes upon reboot
    Same problem here, Quickbooks support has been useless on this issue
