What temp monitor is best to use?
  1. Posts : 187
    Windows 7 Pro 32Bit
    i use HWmonitor at the moment and wanted to know what is the best app to do this?
  2. Posts : 3,028
    Windows 7 Ultimate (x64) SP1
    I don't know about "best" but I use Speed Fan. I also have a Speed Fan gadget on my desktop.
  3. Posts : 291
    Vista/Windows 7
    Core Temp is another good one :)
    Core Temp
  4. Posts : 3,028
    Core Temp
    Seems to only report on CPU temps though (or did I miss something?)
  5. Posts : 6,879
    Win 7 Ultimate x64
    You didn't.
    Not free but personally I prefer Everest with its built in Sidebar support.
  6. Posts : 3,028
    stormy13 said:
    You didn't.
    Yeah, I've heard of Everest. Might give it a try
  7. Posts : 3,427
    oddly... speedfan and everest report 2 different temps on my computer, so you might want to check the temps and see which one looks more "normal" for instance, on my machine speedfan was showing the core temps to be 22 and 23 respectively, everest was showing it at about 37 which sounds right to me
  8. Posts : 1,506
    W7 Ult. x64 | OS X
    I've found that everest works the best, even though it's not free. It allows me to monitor all sorts of temperatures procceses, dll files and more.
    It also allows you to use the following things to display items:
    Logitech GamePanel
    OSD (Similar to Sidebar)
    Sidebar
    System Tray
    Here's a pic of the OSD (Larger) and the SysTray
  9. Posts : 3,028
    Been tinkering with Everest and I like it. It can't read my SSD temp though. Can't find a good monitor that can actually
  10. Posts : 59
    Windows 7 Ultimate x64 & OSX 10.6
    Is your SSD even capable of having it's temps read?
