Windows 7: Help with USB Problems
08 May 2009   #1
cchartman
Windows 7 32-bit
I have recently upgraded form Vista to the 32-bit RC version of Windows 7. Everything works fine up until the point when I remove, or plug in any new USB device. At that point all of my USB ports stop working giving me an error code 19. This happens whether I am changing the USB hard drive, network adapter, or pretty much anything. I have already made sure that all of my drivers are up date prior to unplugging/plugging, and Windows 7 is completely up to date as well. My two 64-bit RC versions do not have this issue either.
Any ideas? Thanks.
08 May 2009   #2
Brink
64-bit Windows 10 Pro
Hello Cchartman, and welcome to Seven Forums.
It may be a issue that occurred during the upgrade from Vista. You might see if doing a repair install of Windows 7 may be able to fix this for you.
08 May 2009   #3
cchartman
Windows 7 32-bit
Doing a repair install has been my short-term fix, but it does not seem feasible to do so every time I want to swap out a hard drive. I'm wondering if anyone knows of any more permanent solutions to this issue.
Thanks.
08 May 2009   #4
Brink
Oh, you didn't mention that you had already did a repair install. If it is still doing this after doing a repair install, then the installation may have been affected somehow with the upgrade from Vista and you may need to do a clean install with Windows 7 instead.
Many problems with video errors and somehow RAM problems
Okay so for a while now i have been having many problems. First off i had a PC with the video card i am using right now(Nvidia GTX 295), and it has been "losing signal" and just plain old crashing. So i bought a PC off my uncle. Its got reletivly good hardware, but i am still getting the same...
General Discussion
USB Problems, Errors and port problems!
I have a Dell Inspiron 1545 laptop, not to long ago I had to replace my hard drive. After that I reinstalled windows 7. Before this the usb devices would charge just not be recognized. Now only ONE port does everything (charge, sync, etc.) the other two just stopped working. I have no clue if its a...
Hardware & Devices
Can't start up my computer. (Driver problems, BSOD, other problems)
Hi I hope I'm placing this in the right section, if not, then could someone tell me where to put it and I'll post it again. I've got a Samsung RV510 laptop with Windows 7 HP 64 bit. About 2 weeks ago, I was watching a Youtube video, had Spotify and Facebook open too, and my computer...
BSOD Help and Support
extract problems, random BSOD errors all those problems
hi guys i dunno why i have many problems with win7 since installation and so far btw i wrote many topics before about my installation and eventually i didn't found any solution so i took my pc to computer shop and they solve the problem after that i installed win7 without any problems...
Problems leading to problems...
Hello, I am new to the forum, and I am hoping someone can help me out. I am attempting to install Win 7RC 64 bit on my system and seem to run into another problem as soon as I solve one. I am now at a problem that has me at a loss. Bear with me as I outline what I have done so far. I had...
Installation & Setup
