Need help connecting home theatre system to my pc
  1. Posts : 4
    Windows 7 Home Premium 64 bit
    I have Phillips HTS3164 DVD Home Theatre System, and i want to play sound on it through my pc. I have a HDMI cable connecting them both, but it does not play the sound. Anybody know how i can get this working?
  2. Posts : 1,299
    Windows 7 Home Premium (64-bit) *** Windows XP SP3 (32-bit), OSX 10.6
    Hi Shifty,
    Just to clarify, are you sure you mean play the Philips system sound through the PC (e.g. play records/CDs out of PC speakers/phones)? Or do you mean play PC sound through the Philips system (e.g. play MP3s out of Home Theater Speakers)?
    Also, it would help if you could fill out your System Specs, please!
    Cheers,
    Walker
    Windows Outreach Team
  3. Posts : 4
    Thanks for the reply. What I mean is that I want to play pc sound through the phillips system. Have also filled in my system specs now. Any way I can solve the problem?
  4. Posts : 6,292
    What would be most help for us to help you is more info on your systems. If we know either the Brand and Model of your computer or the Brand and model of your motherboard we can get some idea of the capabilities of your system.
    Most important would be what you are using for a sound card and video card.
    Also, what did you plug the HDMI cable into on the computer?
  5. Posts : 4
    Im not sure about all my system info. And yes, I did plug it into the computer
  6. Posts : 6,292
    Do you know if you plugged it into your video card?
    The HDMI plug would be right next to the plugs for your monitor.
  7. Posts : 4
    Yep it's right there
  8. Posts : 6,292
  9. Posts : 1,299
    Hi Shifty,
    Please read this post on how to look up your system information. We need your graphics card at least.
    Cheers,
    Walker
