#21
To install on a MB like yours you have to add to the Win 7 installation files at least the SATA, USB3,x and NVMe drivers.
You don't see the NVMe drive and don't have mouse or keyboard because you didn't add the drivers.
Those were added as part of the build process here: Update your Win 7 installation media
It helps if you read it:
AMD_AM4_X399_TRX40_Drivers_win7_81.7z — Яндекс.Дискuse this instead of the usb3 drivers provided in 7updater.
You can uninstall the usb3 drivers from your already applied win7 using dism++ then install the above drivers instead, not in addition to.
