Slow speed, fast speed, slow speed.
Page 4 of 4 FirstFirst ... 234
  1. Posts : 155
    Microsoft Windows 7 Ultimate 64-bit 7600 Multiprocessor Free
       #31
    2wire 2701hgv-w. Perhaps the best option is a new router?
  2. Posts : 543
    Ahh I was looking for one of these the other day with no luck! 2-Wire have very poor support on their products from what I have seen.
    I would suggest a new router yes. If its just a standard ADSL connection then NetGear have always been relicable in my opinion.
    Dave
  3. Posts : 155
       #33
    Would it be wiser for me to use a D Link router considering that's the brand of my adapter? Or does it really not matter? And what type of router should I be looking for?
  4. Posts : 543
    It shouldn't really matter as the routers will use the same encryption. However, if you are happier getting a D-Link router then go for it.
    It maybe worth asking your provider for a recommended router. You need to find out if you're on ADSL/ADSL2+. They will be able to tell you what kind of router you need. I wouldn't buy it off them though as they can sometimes rip you off! If they recommend a 2-wire then hang up lol.
    Dave
  5. Posts : 155
       #35
    Just realised that it's not just the wireless computer, it's all of them. Even the machine connected to the router directly.
  6. 2xg
    Win7 & Win8 64bit
       #36
    A new router is a good idea, you may also try a reset to the factory default setting then reconfigure all from scratch. Do print screens of the router settings prior to the reset.
    How to Reset a 2Wire Router | eHow.com
  7. Posts : 155
       #37
    The settings are exactly the same as they were before I moved house. I honestly don't think it's anything to do with the settings because even the computer that's wired is slow as all hell.
  8. Posts : 543
    As per zxg's post, try resetting the router.
    If this fails, try as different router.
    Dave
