Wireless connectivity problem !, Please Help
Page 2 of 2 FirstFirst 12
  1. Posts : 11
    Windows 7 Home premium 64bit
    ok well, i have a "buffalo router" and it says on the front box Enhanced multiple Security management (AES,TKIP,WEP), and no i dont have another laptop connected to the network, i do have about 3 ipod touches hooked up the the network, and all seem to be running alright, although the connection was alot quicker on the ipods (loading videos etc.) before i started having these problems with my connection on this computer, im starting to think it is a problem with the router :/
  2. Posts : 11
       #12
    ok im going to sum it up easily what im trying to say, pretty much what ever i connect to the wireless router either has incredible low speed or it drops out, my xbox used to connect to my router wirelessly, then it stopped, then a week later im having this problem with my computer
  3. aem
    Windows 7 Ultimate 64Bit
    The other factor could be inteferences causing dropouts. But yeh if you can't figure it out i'd say time for new hardware.
  4. Posts : 11
       #14
    thanks mate ill replace my router and wireless adapter, but would recoment a onboard pci adapter rather than a usb adapter?
  5. aem
       #15
    I fancy onboard/built-in definately. Where possible i always avoid using third party software too, just to eliminate any possibilities of conflicts. If you have money invest in a laptop for wireless connection and have your Pc as wired. G' luck with it :)
  6. Posts : 11
       #16
    thanks mate
