Wireless connection works, wired connection does not.
  1. Posts : 7
    So last night, my wired connection was working. I did not install any new software or download anything. Tried getting on the internet today and nothing. My computer has an IP Address but I can't get onto the internet at all. I can't ping google. I can ping my IP address assigned, can't ping my default gateway...
    I have tried a different ethernet cable and I have changed the switch the computer is connected too.
    I have already uninstalled and reinstalled the ethernet drivers.
    I have already performed an ipconfig /release & ipconfig /renew. I also tried ipconfig /flushdns.
    I have performed a netsh winsock reset, netsh int ipv4 reset reset.log, netsh int ipv6 reset reset.log, netsh int ip reset.
    After performing all of the above I am stuck with the exact same situation.
    Here is my ipconfig /all
    Windows IP Configuration
       Host Name . . . . . . . . . . . . : ADAML-LAPTOP
       Primary Dns Suffix  . . . . . . . :
       Node Type . . . . . . . . . . . . : Hybrid
       IP Routing Enabled. . . . . . . . : No
       WINS Proxy Enabled. . . . . . . . : No
       DNS Suffix Search List. . . . . . : rh.rit.edu
    Ethernet adapter Local Area Connection:
       Connection-specific DNS Suffix  . : rh.rit.edu
       Description . . . . . . . . . . . : Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.20)
       Physical Address. . . . . . . . . : 00-26-9E-00-92-8D
       DHCP Enabled. . . . . . . . . . . : Yes
       Autoconfiguration Enabled . . . . : Yes
       Link-local IPv6 Address . . . . . : fe80::8090:b23e:6b1d:facb%19(Preferred)
       IPv4 Address. . . . . . . . . . . : 129.21.102.102(Preferred)
       Subnet Mask . . . . . . . . . . . : 255.255.255.0
       Lease Obtained. . . . . . . . . . : Thursday, January 19, 2012 11:35:53 PM
       Lease Expires . . . . . . . . . . : Friday, January 20, 2012 2:35:53 AM
       Default Gateway . . . . . . . . . : 129.21.102.254
       DHCP Server . . . . . . . . . . . : 129.21.13.174
       DHCPv6 IAID . . . . . . . . . . . : 301999774
       DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-11-C7-D6-4A-00-26-9E-00-92-8D
       DNS Servers . . . . . . . . . . . : 129.21.3.17
                                           129.21.4.18
       Primary WINS Server . . . . . . . : 129.21.3.95
       NetBIOS over Tcpip. . . . . . . . : Enabled
    Wireless LAN adapter Wireless Network Connection:
       Media State . . . . . . . . . . . : Media disconnected
       Connection-specific DNS Suffix  . : wireless.rit.edu
       Description . . . . . . . . . . . : Intel(R) WiFi Link 5100 AGN
       Physical Address. . . . . . . . . : 00-1E-65-02-37-8E
    Tunnel adapter 6TO4 Adapter:
       Description . . . . . . . . . . . : Microsoft 6to4 Adapter
       Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
       DHCP Enabled. . . . . . . . . . . : No
       IPv6 Address. . . . . . . . . . . : 2002:8115:56fe::8115:56fe(Preferred)
       IPv6 Address. . . . . . . . . . . : 2002:8115:6666::8115:6666(Preferred)
                                           129.21.4.18
       NetBIOS over Tcpip. . . . . . . . : Disabled
    Tunnel adapter Local Area Connection* 8:
       Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
    Tunnel adapter isatap.rh.rit.edu:
       Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
    Tunnel adapter isatap.wireless.rit.edu:
       Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
    My university does not have my computer account or computer blocked.
    Additionally, the link light on the computer is on and blinking.
    Any help is appreciated
  2. Posts : 7
    Fixed it...unplugged the switches, let the power stay off for about a minute. Plugged the power cord back in and it worked.
