Network speed and ethernet cable questions with wifi card question
  1. Posts : 96
    WIN 7 x64
    Debating on going wireless or not: Have an Asus M4A87TD EVO that has RTL8111E PCIe Gigabit LAN controller featuring AI NET2. So Gigabit, Im thinking at least 100/1000. I am wire into my router which puts out high speed and low ping to wireless. Standard Ethernet cables supply the data pipeline, not sure what the transfer speed is on them, If anyone can let me know that would be great.
    I have been eyeballing the super speed ethernet cables, but not sure if it would solve the ping issues I have with desktop, (being too high), and the cost for a 15' line.
    Tried finding a wireless card that handles N+network and 5.0Ghz for my dual band.
    1. What is the standard ethernet cable speed?
    2. Can the standard ethernet cable from router to computer be causing high ping? (have second computer with 3' cable, same issue)
    3. Would it be better to go wireless and forego the wired ethernet cable?
    4. What wireless card would you recommend?
  2. Posts : 28,845
    Win 8 Release candidate 8400
    UGH
    1- what kind of cable? cat 5, cat5 E, cat 6?
    2-Yes if cheap, old, or not shielded.
    3-Not if you are transfering large amounts of data on your internal LAN
    4-An 802.11 "N" card
  3. Posts : 96
    WIN 7 x64
    zigzag3143 said:
    UGH
    Standard----Cat 5
    Probably cheap - But then why does my wireless get fast ping when same type of cable goes from modem to router?
    Given that HD streaming and Gaming I would say lots of data going back and forth
    As noted in the post I know I need a card that handles N network. My question was in reference to manufacturer, dual band card, 300, 600, etc
  4. Posts : 28,845
    Your budget and needs?
  5. Posts : 96
    WIN 7 x64
    No real budget, its flexible, dont want to overpay though. Usage is mainly going to be gaming, will probably buy two so HTPC can have good streaming netflix and other shows.
    Note - must be 5.0 Ghz
  6. Posts : 28,845
    Ethernet would be better for gaming but
    Linksys dual band (up to 350 MB) tons of range, port forwarding for games, and secure.
  7. Posts : 96
    WIN 7 x64
    Okay, I will look into that one then, thank You. The Ping Im getting is killing me on MW3
  8. Posts : 28,845
    How high?
  9. Posts : 96
    WIN 7 x64
    Ping between 520-580. even swapped for a cat5e with no change
  10. Posts : 28,845
    Might be a driver please use this free utility to find out. http://www.thesycon.de/eng/latency_check.shtml
