Help! - crazy ethernet cable problem!
Page 1 of 3 123 LastLast
  1. Posts : 14
    Hi - my internet was working fine - then last night I couldnt connect because Windows 7 said my ethernet cable wasn't connected.
    I have a D-Link ADSL2 modem - and the LAN light doesnt come on.
    Troubleshooting already tried:
    • Using same cable connected my Mac to the Modem - internet worked fine (but my Mac is so old I can't use a lot of websites)
    • Using same cable connected my Windows XP machine.. LAN light on.. but no internet connection (cable unplugged message)
    • Trying a different ethernet cable
    • Unistalled/reinstalled network card on Windows 7 machine and restarting
    • Unplugged everyting, turned off modem at power, restarted.. shut down.. 2 times
    So the cable seems ok, the modem seems ok, the network card seems ok, and it worked 2 days ago but now.. nothing.
    Is there a way to check whether the ethernet port is working?
    Any suggestions as to how I can fix this pesky problem? Or at least diagnose what the problem is? Could it be interference from software? Very perplexing
    THanks in anticipation...
  2. Posts : 13,354
    Windows 7 Professional x64
  3. aem
    Windows 7 Ultimate 64Bit
    You could test the ethernet port by doing a cross-over cable from the problem machine to another. Just connect the ethernet cable (cat 5) from one machine port to the other.
    Configure the tcp/ipv4 of problem machine:
    Ip - 192.168.1.20
    Subnet - 255.255.255.0
    Default Gateway - 192.168.1.1
    Configure the tcp/ipv4 of working machine:
    Ip - 192.168.1.21
    Make sure the port lights are on (ie showing green)
    Then from one machine test ping the other using the above IPs.
  4. zap
    Shell to a command prompt with elevated privileges if needed, and type the following:
    ping localhost
    ping www.google.com
    ipconfig /all
    ipconfig /all | more
    cls
    ipconfig /release
    ipconfig /renew
    Let us know how it goes.
    I also like the previous posters idea using a crossover cable . . . clever. If you currently have Cat5/6 cables that are not crossover, you can purchase a crossover adapter relatively inexpensively.
  5. Posts : 548
    W7 Ultimate 64bit W7 Premium 64bit W7 Premium 32bit WXP Home 32bit
    I agree with J_K, sounds like a bad ethernet card. Fortunately they're pretty cheap.
  6. Posts : 14
    HI - Thanks for the suggestions everyone.. I have tried a few of them
    Took my computer back to the seller - checked out the network card and it connected to his net there with no problem.. so not the card??
    Rang the ISP - I am connected at their end no problem.. did some tests on the modem and it seems that may be where the problem lies. However, my mac connects to the modem and net with no problems so that seems a bit weird.
    It is all very frustrating because I can't seem to analyse what is wrong with my LAN. (all windows 7 says is that I have a faulty ethernet cable... no other diagnosis)
    If anyone has any further suggestions then I would be grateful.
  7. Posts : 13,354
    Have you tried aem's suggestion? Help! - crazy ethernet cable problem!
    That will eliminate the router from the list of possibilities.
  8. Posts : 14
    No I havent tried that one - not sure what a cat5 ethernet cable is??
    I will try it tonight though... I just wish I knew how to fix this pesky problem
  9. Posts : 13,354
    Just run a network cable from 1 PC to the other.
  10. Posts : 548
    One item we haven't thought about is if the ethernet port on the modem is starting to go. It's rare but it can happen. If it's starting to have problems auto detecting the ethernet connection it may look like a bad card.
    It might be worth locking the speed/duplex on his network card and hooking it up again.
