New Build with some recycled parts... Questions/Advice! Please
  1. Posts : 185
    Windows 7 Ultimate 32bit
    Definite!!
  2. Posts : 2,259
    W7 Professional x64
       #12
    Precisely
  3. Posts : 93
    Windows 7 Ultimate 64Bit
  4. Posts : 1,127
    Win7U 64 RTM
       #14
    Ballistic said:
    So after installing and getting everything together... I could possibly just turn on my computer without reformatting and doing a clean install... I mean your saying it's not outside of the realm of reasoning that it could all work fine without reinstalling or doing anything more then adding the hdd and letting it go?
    Possible, but not optimal. Also possible under those circumstances is the neccessity of a Repair Install
    I myself believe it better to start with a clean install.
    James
  5. Posts : 93
       #15
    James
    So repair install then clean install ??? -scratches head-
  6. Posts : 11,424
       #16
    Highly suggest using a Corsair H50 or better yet H70 cooler and please compare with the Cool-it systems. Sealed water systems will cool well beyond any air system I'm aware of with all the risks of water removed. Then upgrade the corsair fan to two Noctura's or similar in a push pull configuration out the back of the case. Heat being the enemy of any system and for sure any OC'd system.
  7. Posts : 1,127
    Win7U 64 RTM
       #17
    James
    No. I suggest a clean install, but if not, putting the old drive with new components may require a repair install.
    Also, since you are changing the motherboard, have you verified that your existing RAM will be compatible with the new board? There is a good chance that it will not be.
    Again, a clean install is the best way to go if you want the best out of your new system.
    James
  8. Posts : 93
       #18
    James Colbert said:
    James
    Why wouldn't the ram work ?? It's DDR2 667 and the mobo is for DDR2 533/667/800/1066
    James
    Why wouldn't my ram work ?? The mobo is rated to work with DDR2 533/667/800/1066... My ram is DDR2 667mhz
  9. Posts : 1,127
    Win7U 64 RTM
       #19
    Something you don't mention is whether you have a retail Win 7 disk or if it came with your HP Pavillion? If it came with your HP (OEM), it will not be of use on your 'new' system regardless of a clean or repair install. OEM windows are locked to the OEM equipment and will not install to a new system or new motherboard.
    If indeed your windows version is OEM, you can buy the upgrade (cheaper) version of win7 only if you have a retail version of XP or Vista.
    James
  10. Posts : 93
       #20
    It's retail
