Windows 7: 4 fans, 3 normal headers + 1 "power fan" header. How to connect?
28 Oct 2010   #21
Lebon14
You know what? I never had an aftermarket fan. Never. And, none of the boxed either from the PC or the box never broke or get noisy. Never. I won't buy anything until it happens.
28 Oct 2010   #22
linnemeyerhere
Windows 7 Ultimate 64
I have had two fans go noisy on me. I've replaced them and also my push/pull fans on my H50 cooler with all Noctura's and the noise level and amount of air they run through the fins of the cooler is amazing. There are areas where IMO the extra cost has paid off. Take lots of pic's and post them of your build !
28 Oct 2010   #23
LiquidSnak
W7 Professional x64
I also demand photos
28 Oct 2010   #24
thefabe
you have received all the information you need so I'm just going to say that I think whenever possible "I think" it's a good idea to not use as many of the MB fan plugs as possible, I would rather use adapters and run them off molex connectors.
Why? Well I have this notion that the less power you draw directly from your motherboard the better off the other hardware will be that requires being powered off the MB.
JMO Fabe
28 Oct 2010   #25
CarlTR6
Windows 7 Ultimate 32 bit
Quote   Quote: Originally Posted by thefabe View Post
JMO Fabe
+1 Darn good advice.
29 Oct 2010   #26
Lordbob75
JMO Fabe
What I do.
Of course, I also have my fan mod...
~Lordbob
29 Oct 2010   #27
linnemeyerhere
Well I feel vindicated thanks LB75 for keeping the added voltage off the mobo.
29 Oct 2010   #28
Lordbob75
Quote   Quote: Originally Posted by linnemeyerhere View Post
Heh.
I have 3 200mm fans and 1 180mm fan in my case. I always had mine plugged right into the PSU because there is not a noise issue with them (they are dead silent).
The fan mod was a fun thing.
~Lordbob
29 Oct 2010   #29
Lebon14
JMO Fabe
Took in consideration. But, now, starting today, I have no more income. My last pay will be next Wednesday. And the money I have remaining will be use to be able to live. They will be connected to the motherboard for the moment.
Btw, the build hasn't started yet. I'm waiting for my PSU, the RAM and SSD to arrive and they should on Monday. Then, I will invite my friend over to build this up~
29 Oct 2010   #30
linnemeyerhere
I'm sure it will all go swimmingly. Take pictures all along the way and the whole wire routing thing takes a ton of time but if you use your head and take your time the best routing will appear to you. I like wire ties but they are a pain to take off for a change so configure all how you like then test the computer and then cinch them down. Good chance the PSU will come with Velcro wraps that work well. If you get into a quandary then give us a post or update.
Good Luck, the Cheese
Win 7 Gamer i7 all fans tested, but no power from either CPU Header
So, that's pretty much it in a nutshell. The CPU Fan works on a system fan header, but no fans work when connected to either of the CPU fan headers. Graphics card fans spin fine, machine lights up, but no video. I have not swapped out the PSU, because I did not think that would affect both CPU...
Hardware & Devices
3 BSOD's after new GPU, "Reference by Pointer" and "BAD POOL HEADER"
Hey all, I've gotten a couple blue screens over the past couple of days. I just replaced my GTX 660 with a 960 over the past weekend and received a Bad pool header BSOD on the 9th, then today (the 11th) 2 Reference by pointer BSOD's. I've done some research and it seems to all point to driver...
BSOD Help and Support
BSOD - Happens randomly. "Bad Pool Header", "DRIVER_VERIFIER"
Hi everyone, I recently have noticed more and more BSODs. I had this problem about 6 months ago and was able to track it down to drivers that came from Daemon tools. I cleared all that out and it fixed the issue. I don't think these new BSODs are related but they might be. This seems to be...
BSOD "Bad Pool Header" and "Page In Nonpage Area" Runs in Safe Mode
Hi, I am having a problem with my newer computer, I just got this rig a few months ago and never had a problem until last Thursday. It Blue Screened on me while I was installing ARC GIS 10.1. From then on it randomly crashes. (I have previously installed ARC GIS 10 and never had a problem.) I...
Random "Bad Pool Header" and "System Service Exception" BSODs
I have been getting these "Bad Pool Header" and "System Service Exception" BSODs for about a day now (the "Bad Pool Header" one tends to pop up more often then the other btw). I ran a registry cleaner which didn't work and ran memtest this morning and it showed that my memory was fine. The BSODs...
