Correct way to connect the termaltake 2.0 Pro water pump.
This is driving me nuts so I figured id ask here if I connected everything right. My Radiator came with 2 120mm fans which are connected using a Y cable. I connected the Y cable to the 4pinCPU_FAN on my motherboard. The water block itself has another 3 pin cable coming off it that I connected to a 3pin-molex adapter coming straight from the PSU. I was told it needs constant power. My mobo also has 3pinSYS_FAN1 ,4pinSYS_FAN2, 3pinPWR_FAN. My SYS_FAN1 is being used by a large 120 quiet case fan. My 3pin PWR_FAN is going to be used for my ram cooler. Have I made any mistakes?
The Layout( I sorta drew it to represent what I have right now. Is this correct? ) This is a thermaltake 2.0 pro water cooeler by the way in case anyone asks.
