corsair h60 water cooler fan noise
Im assuming after today installing the corsair h60 water cooler and switching on the terrible noise from the supplied fan. Im assuming its the fan because obviously its new, but i did a couple of tweaks to my system whilst installing the cooler, i turned the psu the other way around and connected a case fan at the front what i hadnt connected previously, which is the same type of fan i took from the back of the case to install the cooler.
So options, is it ok to replace the fan supplied with the cooler by the one i took out. Ive read i can but need to make sure obviously.
The other thing is this new fan is running at 4250 rpm, whilst the others have hovered around 1100 rpm.
I also purchased 2 pack corsair af120 performance fans, could using one of these be ok and quieter
Many thanks
