#21
I actually had to update the bios to even get the computer to work as it was revision 1.00 out of the box and my cpu required 1.30 so all and any issues occurred on latest bios version after I used an old cpu to update the bios and then installed my proper cpu. < that itself was amusing to work out. motherboard wouldn't display anything other then 0x5a error code.
so....bios is fully up to date and it occurred a few days after the update
2.30 10/16/2013 Instant Flash 2.72MB
heh........after another bios reset its returned to, mobo utilities = 45c on cpu
corsair link =19c speccy = 19c, cpu id = 19c on fx8120 and 40c on cpu? lol...
additional pic...
tried another program mentioned on this thread, it also spits out 2 different temps for my cpu.... I mean if my pc stays at 45c even under load with the water cooling then im happy. but its bizzare to see multiple and varying temp readings for one device >.>
-side note- thoughts on what the 'auxillary' sensor is reading? seems hot
