Windows 7: CPU and motherboard are the same? Sound card not showing?
13 Nov 2017   #1
jseh
Windows 7 Ultimate 64-bit
I am checking out what I actually have in my PC because I want to upgrade it so I downloaded Speccy.
It doesn't show that much more information than device manager.
I'm confused about the CPU/Motherboard because they both show Intel Core i5-3470.
Also, my sound card is not showing, yes it says "AMD High Definition Audio Device" but that's not a model.
Can anyone help me with this?
13 Nov 2017   #2
mrjimphelps
Linux Mint 18.2 xfce 64-bit (VMWare host) / Windows 8.1 Pro 32-bit (VMWare guest)
The CPU plugs into the motherboard -- that's why you see Intel Core i5-3470 listed with the motherboard.
What sort of upgrade do you want to do? Do you want to make the computer faster? What you use the computer for will help determine what would be the best thing to do to get better performance.
Two things which usually help are (1) more memory and (2) converting from a mechanical hard drive to a solid state drive (SSD). Since you have 64-bit Windows, you can probably benefit from more memory, if you aren't already maxed out. A solid state drive is always faster than a mechanical hard drive, and you will see that benefit every time there is a disk read or write, such as when Windows starts up, or when you save something to the hard drive.
If you do a lot of gaming, then a better graphics card could help, unless you already have a good graphics card.
If your network interface card is old, you may get a better internet speed by installing a new card.
You could probably benefit from a better CPU. But you will need to get one which is fully compatible with your motherboard, memory, etc. Also, you need to handle the CPU with extreme care, and then use a good thermal paste to attach the heat sink to the new CPU. I would not advise changing out the CPU unless you know exactly what you are doing, that is, if you've done it several times before.
Sometimes the cost of upgrading your computer is more than you will pay for a new computer. Perhaps you will want to just add memory and install an SSD. Those two steps will give you just about all of the improvement you are likely to get.
13 Nov 2017   #3
jseh
Quote   Quote: Originally Posted by mrjimphelps View Post
I want to play videogames. Right now Fallout 3 advises me to use Medium settings instead of High or Very High.
I want to play Very High at a proper speed.
14 Nov 2017   #4
RoasterMen
Windows 7 Home Premium 64-BIT
You're missing the motherboard's AUDIO driver. The only AUDIO drive installed is the one needed by your graphics card to drive audio signals on HDMI.
Is my motherboard showing near-to-death symptoms?
I've noticed this yesterday. My PC will not boot past the BIOS splash screen (My motherboard is MSI MS-7525 and therefore is OEM and not supported by MSI.) Is the motherboard going to die? I'm thinking of getting any G31 Motherboards (Too lazy to install drivers) and I need an upgrade to Core 2...
Hardware & Devices
Motherboard showing the wrong CPU
I have a i5 3570k CPU and Asus P8H77V-LK Motherboard but on the BIOS it says i5 3330 3.00Ghz and also on the device manager too I get 10mins of google chrome or any other program and the whole system freezes Can I anyone please help me on this?\ Thanks
Hardware & Devices
No sound from speakers but showing sound graph on speaker control
I have an MSI 785GTM-E45 Mother Board. I have no sound coming from the speakers. Tried new speakers and still no sound. If I click on the speaker Icon on the bottom right it shows the speaker graph going up and down as sound is being produced. I tried the head phones and nothing coming from them...
Sound card sounds no better than integrated motherboard audio?
I purchased the Creative Sound Blaster Audigy SE 7.1 Channels 24-bit 96KHz PCI Interface Sound Card, a cheap, $30 card, and was expecting some improvement over my computer's integrated motherboard audio (Dell XPS 420), but I can't really tell the difference between the two. Is it possible for the...
Motherboard won't detect my sound card
I recently changed my OS to Windows 7 x86 from Windows XP on my podunk 2002 Gateway. Suddenly, it wouldn't play sounds and said there was no sound device. I thought I needed a driver for my Creative Sound Blaster card but I don't think any of my PCI slots are working because it won't even recognize...
Hardware & Devices
