Power Options/Power plan settings?
  1. Posts : 111
    Windows 7 Pro x64 RTM
    From Windows 98SE/2000/XP SP3 I always set my power settings as always on/never shut down (hard drive always on) with the exception of turn off display after 10 mins. Both my PCs are on for about 16-20 hrs each day and I always shut them down manually every night.
    Now in Windows 7, I created a custom plan that basically more or less similar to the above, always on/never shut down/never sleep, turn off hard drive after 10000 mins (basically never off) except to turn off display after 10 mins.........well, last night I thought of trying out the "Balanced" (recommended) plan....and after 30 mins of inactivity, both my PC were off/shut down and I had to press the power/on buttons on both my PCs to bring them back (cause clicking the mouse/pressing any key on the KB wouldn't bring them back), is this normal or the way the Balanced plan supposed to work?
    What's your or how you set your Power Options/Power plan settings on your Windows 7?
    Thanks in advance.
  2. Posts : 463
    Windows 7 Build 7600|16384- 64bit
    Balanced does turn your hdd and things off after 30 minutes(put it to sleep). Just go in there and change all the sleep things to never, or set them to 0 minutes. After you select your new plan, make sure your screensaver is on as well.
  3. Posts : 1,962
    Windows 7 x64 (Ultimate)
    Is there an easy way to revert back to Windows 7 default settings when it comes to Power Options/Power Plans/ScreeSaver/Display options???
    I am having an issue with this as well and someone mentioned it should be my settings and/or I must off have ticked/unticked something I shouldn't have.
  4. Posts : 71,977
    Hello AstaLaVista,
    This can help show you how to reset it. :)
    Power Plan - Restore Default Settings
  5. Posts : 1
    Hey,
    I have a problem setting any of power options to work properly in my Win 7.
    Problem is that when i set display to turn off at any time, it turns off and turns on after 1-2sec. This also happens when i put computer to sleep at any time.
    Dunno why this is happening.
    Any help would be appriciated.
    Tnx
  6. Posts : 5,642
    Windows 10 Pro (x64)
    ben07 said:
    ...turn off hard drive after 10000 mins (basically never off...
    You know...you could just use 0 so it never turns off.
  7. Posts : 1,170
    XP Pro SP3 X86 / Win7 Pro X86
    Thanks in advance.
    Ok... no matter what plan you're on there is a settings change you should make...
    Control Panel -> Mouse -> Hardware -> Properties -> Power Management
    Check "Allow this device to wake the computer"
    Control Panel -> Keyboard -> Hardware -> Properties -> Power Management
    Now if the machine does end up in sleep mode, your mouse and/or keyboard will get you out of it.
