Power Options/Power plan settings?
From Windows 98SE/2000/XP SP3 I always set my power settings as always on/never shut down (hard drive always on) with the exception of turn off display after 10 mins. Both my PCs are on for about 16-20 hrs each day and I always shut them down manually every night.
Now in Windows 7, I created a custom plan that basically more or less similar to the above, always on/never shut down/never sleep, turn off hard drive after 10000 mins (basically never off) except to turn off display after 10 mins.........well, last night I thought of trying out the "Balanced" (recommended) plan....and after 30 mins of inactivity, both my PC were off/shut down and I had to press the power/on buttons on both my PCs to bring them back (cause clicking the mouse/pressing any key on the KB wouldn't bring them back), is this normal or the way the Balanced plan supposed to work?
What's your or how you set your Power Options/Power plan settings on your Windows 7?
Thanks in advance.
