Get better FPS while using less processor power??
  1. Posts : 122
    While playing League of Legends I get better FPS while setting my max processor power around 70% rather than the full 100%.
    At first I thought it was a heat issue but the problem occurred within 15 minutes of having the computer on, also it seems to go away almost immediately after setting the max processor use to a lower value.
    So you ask, why not just play without maxing settings? Because now with limited processor use I cannot run FRAPS at the same time. If anyone knows what may be causing this, any advice would be great.
  2. Posts : 687
    Microsoft Windows 10 Professional / Windows 7 Professional
    Maybe the processor is throttling because of heat.
  3. Posts : 6,668
    Windows 7 x64
    If this is the machine listed in your specs, I'm amazed it runs at all.
    • Processor Intel Core 2 Duo T6500 / 2.1 GHz
    • Multi-Core Technology Dual-Core
    • 64-bit Computing Yes
    • Data Bus Speed 800.0 MHz
    • Chipset Type Mobile Intel GM45 Express
    • Graphics Processor / Vendor Intel GMA 4500MHD Dynamic Video Memory Technology 5.0
    • Video Memory 128.0 MB
    • Max Allocated RAM Size 1759.0 MB
    Your video device is using shared system ram on a laptop, which traditionally are horrible gaming platforms to begin with. That you are gaming on that system with any kind of tolerable rate to begin with is amazing to me.
  4. Posts : 122
    Yes that would be the same laptop I am speaking of, and it was running fine with the CPU on max settings a couple days ago. Is there an application besides task manager that monitors the percentage of CPU being used more thoroughly, or that can detect throttling.
    There is an option to throttle CPU rather than speed up the fan, I have tried having that both on and off with no such luck.
  5. Posts : 5,642
    Windows 10 Pro (x64)
    Resource Monitor will tell you the current "Frequency" of the processor. The Frequency is Throttling.
    Start Menu > Search "Resource Monitor"
