Help system temp high and CPU temp low?!
  1. Posts : 2
    Windows Ultimate 32bit
    Hi!
    I have this problem with Asus p5q3 motherboard my system temp goes up to 60-70(celsius) and cpu (intel core 2 quad q9550) temp is low as 30-40(celsius).
    So how can system temp be that high?
  2. Posts : 1,781
    Windows 7 Professional SP1 32-bit
    That can't be right - I'm guessing that the reported temperature is simply wrong.
    What are you using to monitor these temperatures? I suggest trying Speedfan in Windows: SpeedFan - Access temperature sensor in your computer
  3. Posts : 2
    I'm using Ai Suite v.1.05.32 but ill try that what you linked :)
    SpeedFan 4.44v shows too system temp. 59 :O
  4. Posts : 1,781
    And the CPU temperature still as low?
    ...Could it be possible that they're somehow swapped around and the mobo temp is really the CPU temp and vice versa?
