Best way to recover from "sleep" without using the Power Button?
  1. Posts : 19
    Windows 7 Professional 64 bit
    I have a new Dell XPS 8300 with Windows 7 Professional. I would like to be able to "wake" the computer withput having to use the Power Button.
    My current power settings are to sleep after 2 hours and hibernate after 1080 minutes (1080 minutes seems to be the default.) Sometimes I can wake the computer by pressing the "quarter moon" key (or other keys), but most of the time I have to use the Power Button which will probably wear out after much of this.
    So my question is: what is the best power setting to avoid using the Power Button to wake the computer?
    Thanks.
  2. Posts : 1,533
    Thanks.
    Try pressing the spacebar on your keyboard. The enter key may work also. Sometimes, unplugging a usb mouse can wake a computer, although I would not recommend you do that to wake your pc
    Also, you have to use the power button to wake the pc from hibernate. i don't think the power button will wear out. I have a 7 year old pc with a power button that's been pressed probably hundereds of times and the power button still works every time I press it.
  3. Posts : 19
    Thanks Windude99 but I get the same result with the spacebar and enter keys as I do with the moon key.
    But if you do this all the time with your power button, that's consoling.
    I really don't understand the 1080 minutes before going into hibernate. That's 18 hours, so it really shouldn't hibernate except overnight. The computer seems to be doing this after going into sleep, rather than hibernate. In fact it should never get to hibernate because I turn it off at night.
  4. Posts : 1,533
    Just disable hibernate:Hibernate - Enable or Disable
    Scroll down to option 4.
  5. Posts : 19
    I'll sure try that. However, it doesn't appear to me that it is ever inactive the 1080 minutes (18 hours) to attain hibernation.
  6. Posts : 1,533
    I hope it works out:)
  7. Posts : 6,330
    From an elevated CMD prompt type Powercfg -devicequery wake_armed
    This will list the devices that can wake the pc
    If your keyboard and/or mouse aren't listed you can enable wake for them
    To enable a device the command is powercfg -DEVICEENABLEWAKE "............."
    You will need to change the ............. to your device
    To list ALL your devices enter powercfg -DEVICEQUERY all_devices
    To get help for this command enter Powercfg /?
  8. Posts : 19
    Thanks, David. My keyboard and mouse are both listed and have been working, but not always. It's just that I don't particularly want to have to use the power button every time I wake it from sleep.
    I've disabled hibernate and will wait to see if that helps. However, I'm not sure my computer ever goes into hibernation.
  9. Posts : 6,330
    Ok, figured it was worth checking.
    Odd that they work sometimes, but not always.
    I've never seen that before.
    If you have another KB/mouse you could try those.
    Or, re-install your current KB/mouse.
    You could also run a system file check SFC /Scannow
  10. Posts : 1,533
    Are the keyboard and mouse Wireless?
