Post upgrade: Win7 Home premium, Extreme speed issues.
  1. Posts : 2
    win 7 home 64
    Alright: I'll divide this into sections and explain everything I've been dealing with and done in the last few days. To be blunt, I'm out of ideas and I need help.
    Section 1: pre upgrade
    Pc stats:
    Intel DBX38BT motherboard
    Intel core 2 quad Q9300 processor
    Nvidia 9800 gt
    4gb of OCZ 10300 ram
    2x 500 gb 7200 RPm SATA Western Digital drives
    Liteon dvdrw drive
    Windows xp pro
    Im a gamer and my pc was optimized to do so circa 4 years ago, I could easily run even current gen games like Tera on medium settings, alt+tab and have a web browser and internet radio going with no issues. Cpu usage I never remember seeing above 80%, ever.
    Being honest, this was the 3rd pc Ive built and I was pretty confident about my computer knowledge to do this myself.
    I bought on newegg:
    Nvidia gtx560
    16gb of Corsair vengeance RAM
    and win 7 home premium about a week ago and this is where the problems started
    Section 2 -- The upgrade itself
    The physical installation of the new graphics card and all 4 of the corsair RAM dimms went without a hitch, I did have a RAM POST error, but simply reseated the dimms and windows booted perfectly. So I went into XP updated my drivers for the graphics card (temporarily) and began backing up my critical data.
    About an hour later I restarted and went into my BIOS to reconfigure for Win 7 installation. I accidentally disabled USB on boot though I dont remember doing this as well as the expected switching of boot order.
    Dropped the win 7 dvd into my DVD drive and verified it was set to master on the jumper (IDE DVD drive)
    saved and rebooted
    naturally I couldnt start the boot from dvd drive with no keyboard because I had disabled the USB (no ps/2 port on this board) so I set about flashing the bios which I had never done on this board. I removed power and the cmos battery, waited 10 mins, pressed the power button to clear any extra power... reseated everything and booted up
    no numlock light on keyboard, it was still disabled. I tried this 3 more times, before reading online that this board has a jumper made for this exact situation, set the boards jumper to configure and got into bios just fine
    set it to boot to dvd drive and tried again
    nothing.
    Section 3 -- Win 7 installation
    went all the way into windows and the DVD drive was showing nothing was in it.
    physically the disc looked fine so i went to my fathers house and tested it in his pc, and it worked just fine.
    2 days later I had a SATA dvd drive i borrowed from a friend and managed to get Win 7 to install
    during win 7 installation Iclicked the "format" button thing, but I dont remember it actually taking any time, I deleted the old partitions and remade them into the recommended ones (win 7 newbie)
    Windows 7 comes online and as soon as the desktop hits, im pushing 80% cpu usage, so I let it go for 2 hours thinking it may just need to run its course
    (pc has no internet connection right now)
    I come back to it and its still idleing around 60% cpu but I tried to install the Nvidia drivers only to have it lock up on me with a glaring Not Responding quote
    so I rebooted and gave it an internet connection to register the windows and let it update completely
    computer remains almost completely unusable, as im typing this it is taking literally 10 seconds for the typed digits to appear. current pc stats with ONLY IE working
    are CPU at 45% Ram @ 1.8gb / 16
    cpu spiking to the 80s
    Section 4 -- Already attempted fixes
    I ran malware bytes
    and AVG niether found anything
    I gave the dvd drive back so I have no cd / dvd drives to work with, I do have a USB pen drive.
    Ive tried each RAM stick individually and none post error
    Ive gotten up to date Bios installed and have all drivers that are recent
    Edit: Attempt update: I optimized windows, transparency is off as well as several other thinkgs like gadgets and printer services, still almost no change to cpu stats.
    I thought i did everything right =(
    please help...
  2. Posts : 2
    win 7 home 64
    Forget it, Im an idiot apparently. It seems I must have bought incompatible RAM with my motherboard / processor. My board supports 1st gen GDDR3 but i guess these cards are a bit faster than its capable of supporting, and Im unaware of a way to downclock them to supported speeds
