My pc has better parts than my girlfriends but hers is way faster why.
Page 2 of 2 FirstFirst 12
  1. Posts : 1,045
    Win8/8.1,Win7-U64, Vista U64, uncounted Linux distor's
    Dust buildup in lap tops is very common, when it gets bad you have to open the machine and physical clean it. Your fan is 3 years old, I would replace it while inside. You could install a new SSD while doing the fan. Then a clean install of W7 and you'll be much faster.
  2. Posts : 2,409
    Windows 7 Professional 32-bit/Windows 8 64-bit/Win7 Pro64-bit
       #12
    I used to get cooling errors because of build up so i used a dust blower at the fan and after that, i got no more errors.
  3. Posts : 11,424
    Windows 7 Ultimate 64
    Another aspect of her speed advantage could be her wireless speed. Some lappys have really poor WiFi performance. Look to find a ssd with 256gb of capacity or larger if needed and affordable. Then I used my stock spinner in an external usb powered enclosure, but then I use 64gb SD card in mine for data back up and more portable performance. Don't discount the ssd as it will also enhance battery run time as well as noise, vibration and heat!
  4. Posts : 2,409
       #14
    I would reccomend a Samsung 840 EVO if getting a SSD.
  5. Posts : 1,413
    Windows 7 Home Premium 64Bit
       #15
    Devilz said:
    Cooling pad doesn't do the job and it make usage of laptop difficult.
    Not completely correct, It depends on who make it and the overall quality, you will get some really cheap ones, and some quite expensive ones, I have tried one before and i didn't notice too much of a difference, maybe 5-8 degrees but that 5-8 degrees can be a lot if the temps are really high, also the one i used wasn't cheap but it was expensive either, somewhat mid range, it was easy to use and done the job i needed it to.
  6. whs
       #16
    bigboi972 said:
    cool guys thanks for the input is it possible to easily change the hard drive of a laptop.
    Very easy. SSD - Install and Transfer the Operating System
  7. Posts : 319
    Microsoft Windows 7 Professional 64-bit
       #17
    I will most definitely consider replacing my fan and getting an ssd im just really worried about opening it and breaking it
  8. whs
       #18
    To replace the disk, you only have to open the disk bay. That's easy. The fan is another story. You have to watch the wires that go to the screen. Note that a SSD produces a lot less heat than a spinning disk - in fact it produces no heat at all.
  9. Posts : 1,269
    Windows 7 Ultimate Retail Box (64-bit installed) + Service Pack 1
       #19
    OP's RAM is also very slow, it's not remotely close to being a good laptop in 2014.
    For replacing the hard drive with SSD I would look at this:
