Any way to auto switch power plans when plugging in to charger?
  1. Posts : 730
    Windows XP Pro SP3, Windows 7 Pro 32-bit, Windows 7 Ultimate 64bit, Windows XP Home SP3
    anyone know how to do this? when plugging in to AC adapter, the system switches to a different power plan?
  2. Posts : 20,583
    Win-7-Pro64bit 7-H-Prem-64bit
    In what way,
    There are already different settings for plugged in and battery usage
    Power Plan Settings - Change
  3. Posts : 166
    windows 7 ultimate 64 bit
    It is possible with AVG PC Tune up.
    The software comes with PC optimization mode with standard,economy and turbo mode.
    It automatically switches to economy mode when running on battery and is restored to normal mode when running on ac supply.It changes its mode automatically based on power supply.
    It also consists of turbo mode which is efficient for gaming.
    Attached Thumbnails Attached Thumbnails Any way to auto switch power plans when plugging in to charger?-capture1.jpg   Any way to auto switch power plans when plugging in to charger?-capture2.jpg
  4. Posts : 72,050
    Hello Zapp,
    In addition, here's an option to be able to quickly change power plans via your desktop context menu. :)
    Power Plan - Choose from Desktop Context Menu in Windows
  5. Posts : 730
    let me try to be clear:
    when on battery, I want 'Balanced" plan with all my custom settings [already done]
    when I plug into AC Adapter I want windows 7 to automatically switch to "High Performance" plan [which I have setup, but I have to manually change over from Balanced to High Performance]
    my understanding is that high performance features such as the use of overclock/turbo settings are not available in "balanced" or the "power saving" defaults. but I could be wrong... wouldn't be the first time
  6. Posts : 20,583
    I believe the Balanced power settings are best all around let windows manage the settings that's why balanced is there
    Cheers.
  7. Posts : 730
    ThrashZone said:
    "I believe" the Balanced power settings are best all around let windows manage the settings that's why balanced is there
    Cheers.
    I didn't know we dealt with belief systems here... Oh! yes we do... just take a look at the "best anti-virus" thread!!
    the issue is maximum performance.
  8. Posts : 20,583
    Brink posted an alternative to switch manually,
    Belief system works very well depending on how much junkware is installed :)
    Cheers.
  9. Posts : 4,776
    A workaround
    I'll just throw this in. It's not a perfect solution but it's possible to change power plans just by running any process that you care to define.
    Any way to auto switch power plans when plugging in to charger?-process-lasso.jpg
    This screenshot shows the Power Plan changing when EmEditor is run then being restored to the original Power Plan when the process stops.
    I can't figure out if any additional process runs when a charger is plugged in - or at least I couldn't track one down on my machine.
    Last edited by Callender; 22 Oct 2014 at 17:08. Reason: Delete info that's not needed
  10. Posts : 5,642
    Windows 10 Pro (x64)
    It is okay to be wrong, which you are. Turbo boost and overclocking are not affected by which plan you have enabled. It is just how they are configured with their default settings.
    For example you can configure the high performance mode to be super power saving if you wanted. The actual plans are just setting profiles to quickly change as the need arised.
