Windows 7: Need help in overcoming a problem in trying to shrink my OS (C) volume
25 Dec 2016   #1
provlima
I am trying to shrink my C partition to get more space on my Data partition.
My C partition is 191 GB and shows 65GB free and I assume 126GB of used space but when I total up the size of the files on the C drive (in the show hidden files mode) I only get a total of 99GB. The math doesn't add up.
Before trying to shrink C, I defragged the partition using W7. When I then attempted to shrink the C partition by querying the volume for available shrink space it showed that I could only shrink it by only 304 MB!
Is there a way I can overcome this problem? Perhaps by using another software program.
See screen shots below
Need help in overcoming a problem in trying to shrink my OS (C) volume-partition-scr.png   Need help in overcoming a problem in trying to shrink my OS (C) volume-results-scr-shot.png
25 Dec 2016   #2
DavidE
I use MiniTool bootable CD to resize partitions, then Windows isn't running, more space can be shrunk on [C].
Bootable Partition Manager| MiniTool Partition Wizard Bootable Edition
I backup up everything to a different drive so i can restore/recover BEFORE making any changes.
For the OS [C] drive i use Macrium Reflect free image backups.
Macrium Reflect Free
To get a better look at space used i have WizTree, WinDirStat, and TreeSizeFree - all free and portable.
imho, WizTree is the best.
Antibody Software - WizTree finds the files and folders using the most disk space on your hard drive
Before making any changes - BACKUP, BACKUP, BACKUP
hth
Can't shrink volume [SSD]
Hello.I want to shrink my volume,create a new partition so I can install windows xp on top of windows 7 and use em both using dual boot. Is there any way I can fix this? Thank you! http://i.imgur.com/zP3CnEs.png
Performance & Maintenance
"Shrink Volume" problem on partition
My OS is Win 7 Ultimate 32bit with SP1 and all updates installed. 320 GB HDD with 4 partitions : C:\ (System partition-Primary) and 3 partition (Logical) use to save my data! Now I want to create new partitions for my various data from F drive (last partition) but I can't shrink this volume. It...
General Discussion
Still cannot shrink volume
I deleted all shadow copies, first via Disk Cleanup and then via vssadmin, all per your instructions. It didn't help. I then went in and disabled System protection. It didn't help either. Disk manager still says I only have 462756 MB shrink space out of a total of 953867 MB (NTFS), leaving...
General Discussion
I cant shrink volume please help...
My System contains two partitions... http://i39.tinypic.com/21o24pd.png As shown in above figure, my os partition size is 222 GB. Free space in OS partition is 85 GB. I want to Move 80 GB free space of OS partition to second Partion(F:) to do this, I tried to Shrink the OS volume. But...
General Discussion
Can't shrink volume.
I'm on W7 now, and wanted to have Windows XP too. So I decided to make another partition and install XP on that. But the problem is I can't shrink the volume, it will give me this error all the time. The Virtual Disk service and everything connected to that is enabled and running. ...
Hardware & Devices
