Windows 7: HP 8300 error 515 power supply fan not detected after upgrading PSU
27 Sep 2019   #1
realflow100
Windows 7 Pro x64
What do I do to bypass/ignore this error? I can SEE the fan is spinning just fine but its so annoying having to press F1 every time i turn on my pc
please help
The bios does not help me. the only option is "bypass F1 prompt on configuration changes" but that does not stop the F1 prompt for power supply fan not detected problem.
27 Sep 2019   #2
SIW2
Vista x64 / 7 X64
YouTube
another method using a motherboard jumper
YouTube
27 Sep 2019   #3
realflow100
Windows 7 Pro x64
Too complicated and mine is HP 8300.
is there another way? Can I just run a jumper wire from CPU fan signal to the fan signal for the PSU?
28 Sep 2019   #4
SIW2
Vista x64 / 7 X64
You can try. If it doesn't work, you could try a mobo jumper as in the second video.
28 Sep 2019   #5
realflow100
Windows 7 Pro x64
motherboard jumper wont work as its not a chassis fan thats the problem. its the "power supply" fan specifically so i dont think that will work.
I'll try the wire fan jumper thing later.
Win7 Power Supply Not Detected
I'm running my Windows 7 x64 on an Alienware M17x laptop. My computer recently disconnected from it's power supply source to run on battery because the power supply cable unplugged. Immediately, the computer attempted to hibernate because the battery is bad. I then plugged the cable back in and...
Performance & Maintenance
Power supply surge detected every reboot
Hi guys I get a power supply surge every time I reboot (its been like this for 3 days now) and I have to press f2 to load defaults and continue then it boots up fine. I want to know if I absolutely need a new power supply? or is there anything else I can do to resolve this. Thanks ...
Hardware & Devices
Power Supply Surges Detected - Computer Keeps Shutting Down
Hi There. My computer keeps shutting itself down with the following error message: "Power surges detected during the previous power on. ASUS anti-surge was triggered to protect the system from unstable power.......(see below for photo of screen). So I bought a UPS in the hopes of...
BSOD Help and Support
External Hard Drives without their own Power Supply are not detected.
First of all I am sorry of this has been answered somewhere, but I haven't been able to find it and I really need a solution. My desktop does not detect and external hard drive that do not come with their own power supply. I have many externals that also plug into the wall and they are working...
Hardware & Devices
what to look for when upgrading your power supply
I have an old computer and i want to upgrade to windows 7. My video card wont support Windows 7. I cant find a video card that my system can handle with only a 270 watt power supply. What do i look for when upgrading my power supply? I have a HP d530 CMT.
Twitter Facebook
