Overheating: Power Options, supply voltage, powercfg -energy errors?
Hi, this is all a bit complicated.
The short version: I discovered an over-heating issue on my laptop, a Toshiba Satellite C660, switching itself off twice (while I was attending) - once during the Windows Experience Index CPU stress test, the other while Kaspersky did its default virus scan. It might also have shut off while unattended, maybe during a Kaspersky scan, as I vaguely remember once or twice finding the machine off after I got called away, rather than sleeping as it should. I also have an over-voltage power supply, which I swapped for a defunct one. I'm not sure how to tweak the power settings for best cooling effect under high load, and apowercfg -energy
report was incomplete, scrambled and showed various errors (USB suspend and CPU timing).
Longer version: The crash during WEI testing led me to start digging into the power settings a bit more (which I tweaked from default earlier), and I installed Open Hardware Monitor to keep an eye on the temperature. On the Kaspersky scan, OHM was running and I saw the CPU reach 90C.
Then I did apowercfg -energy
report, which exposed a general USB-not-entering-suspend-state issue, for which no solution seems to exist online! Whether that's related is another point entirely.
Years ago, after a fresh install of Windows 7, I tweaked the Advanced Power Settings because the fan was a bit obtrusive, kind of dithering on-off, most of the time. I changed the "Toshiba Power Saver" setting (installed app from Toshiba), which has Cooling Methods: 'Maximum performance' and 'Battery optimized'.
I've just checked now to see which one I'd changed, and it's immediately obvious - if I put it on Maximum performance, the fan usually kicks in (lowish) and dithers on and off fairly often; if I put it to Battery optimized, it goes off (or so low I can't hear it) unless there's a more obvious load.
It seems unlikely to be the cause of the overheating, since it's not a problem in general use, just these high-stress occasions (and WEI presumably overrules such things to see what the system can do).
The other Advanced Power Settings are the Wireless Adaptor Settings > Power Saver Mode (Low power saving, Medium and High Power saving, and Maximum performance), the Intel Graphics Settings > Intel Power Plan (Maximum performance, Balanced, and Battery saver), and the PCI Express > Link State Power Management (Off, Moderate, and Maximum power savings). I'm not sure how any of these affect heat production, as opposed to battery power (which I'm not so bothered about, as I'm almost always on mains). Perhaps I should put the whole (Balanced) plan back to defaults or tweak some more. (The ones currently set are in italics.)
Now, the other thing I notice (thanks to Open Hardware Monitor) is that the system seems to have ignored the option (in the same list of Advanced Power Settings) to put a limit on the Processor Power Management. It has max and min settings for the CPU for each power plan, which were at 100% and 5%. I decided to put it to 90% max to throttle the CPU and hopefully at least get through the rest of the Kaspersky scan (which went fine, hardly breaking into a sweat). But OHM reports it's been up to 100% anyway since then, so I'm not sure what's the point.
I found a suggestion to run a system energy report, which was weird - first off, it didn't save a valid html file (which I've also seen other mention of in this USB issue). I read through it in a text editor and fixed the html, and it shows that various USB devices aren't entering Suspend. Nobody seems to know how to fix that. There are also Timer Resolution warnings and "CPU Utilization:Analysis Error". (I've pasted the output below. I messed up some of the formatting copying it off the page, but hopefully it's readable.)
I've heard that Toshiba bloatware is generally a damn nuisance, and I might try uninstalling that additional app for power management in case it's confusing the Windows one (or possibly I have the wrong version - it was a long hard trek to reinstall Windows and get the drivers after my hdd broke, and it's an old, second-hand machine on its third OS and second drive).
Or is the whole issue from sticking an over-voltage power supply into it? I'd been having battery problems and got a new one, then discovered it was mainly/also the power supply. I discovered I had another one from a completely different machine with the same plug, read the spec and researched online, and decided it was worth a shot. It's been showing no obvious problem (unless that's causing this problem!). The spec on the old one is 19V, 3.4A, but when I tested it with a meter, it was cycling up and down all the time, so I don't know what it was actually putting out. I think they usually give out more volts than they say. The 'new' one is rated at 20V, 3A, but it's putting out a steady 21V according to my meter (same polarity, of course, and with a capacitor or whatever they are just short of the business end). I haven't tried any apps reporting voltages yet, as I've no idea what I'd be looking for. I'll get a correct power supply, but I suspect it's something else. If the other was putting out 20V rather than 19V, then 21V is only 5% over, which most sites say should be fine. If it was actually 19V, then 21 is 10% over, which is a bit much.
Sorry for the long complicated story! Maybe something jumps out as definitely wrong and fixable if you're au fait with these things. It would be nice if I could tweak and then run some full-on CPU test, but I'm concerned that overheating it repeatedly might do it irreparable damage. All this may be a bit early and I should see how things go, but if you spot anything at all that I should do something about, be my guest. It's happily tootling at around 42C at the moment.
Power Efficiency Diagnostics Report
Computer NameJF-TOSHScan Time2020-01-07T21:15:08ZScan Duration60 seconds System ManufacturerTOSHIBASystem Product NameSatellite C660BIOS Date05/09/12BIOS Version2.00OS Build7601Platform RolePlatformRoleMobilePlugged IntrueProcess Count69Thread Count1105Report GUID {d192fd5d-6d59-4163-82b6-413ded7e353b} Analysis Results
Errors
USB Suspend:USB Device not Entering Suspend
The USB device did not enter the Suspend state. Processor power management may be prevented if a USB device does not enter the Suspend state when not in use.
Device NameUSB Mass Storage DeviceHost Controller IDPCI\VEN_8086&DEV_3B3CHost Controller LocationPCI bus 0, device 26, function 0Device IDUSB\VID_0BDA&PID_0138Port Path1,3
Device NameUSB Root HubHost Controller IDPCI\VEN_8086&DEV_3B3CHost Controller LocationPCI bus 0, device 26, function 0Device IDUSB\VID_8086&PID_3B3CPort Path
Device NameGeneric USB HubHost Controller IDPCI\VEN_8086&DEV_3B3CHost Controller LocationPCI bus 0, device 26, function 0Device IDUSB\VID_8087&PID_0020Port Path1
Warnings
Platform Timer Resolution:Platform Timer Resolution
The default platform timer resolution is 15.6ms (15625000ns) and should be used whenever the system is idle. If the timer resolution is increased, processor power management technologies may not be effective. The timer resolution may be increased due to multimedia playback or graphical animations.
Current Timer Resolution (100ns units)10000Maximum Timer Period (100ns units)156001
Platform Timer Resolution:Outstanding Timer Request
A program or service has requested a timer resolution smaller than the platform maximum timer resolution.
Requested Period10000Requesting Process ID4000Requesting Process Path\Device\HarddiskVolume2\Program Files (x86)\Kaspersky Lab\Kaspersky Free 20.0\avpui.exe
Power Policy:Sleep timeout is long (Plugged In)
The computer is configured to automatically sleep after longer than 30 minutes.
Timeout (seconds)2700
Analysis was partially unsuccessful. Some results are available, but they may be incomplete.
Platform Timer Resolution:Timer Request Stack
The stack of modules responsible for the lowest platform timer setting in this process.
Requested Period10000Requesting Process ID4000Requesting Process Path\Device\HarddiskVolume2\Program Files (x86)\Kaspersky Lab\Kaspersky Free 20.0\avpui.exe Calling Module Stack\Device\HarddiskVolume2\Windows\SysWOW64\ntdll.dll
\Device\HarddiskVolume2\Windows\SysWOW64\winmm.dll
\Device\HarddiskVolume2\Windows\Microsoft.NET\Framework\v4.0.30319\WPF\wpfgfx_v0400.dll
\Device\HarddiskVolume2\Windows\SysWOW64\kernel32.dll
Power Policy:Active Power Plan
The current power plan in use
Plan Name OEM BalancedPlan GUID{381b4222-f694-41f0-9685-ff5bb260df2e}
Power Policy:Power Plan Personality (On Battery)
The personality of the current power plan when the system is on battery power.
Personality Balanced
Power Policy:Video Quality (On Battery)
Enables Windows Media Player to optimize for quality or power savings when playing video.
Quality Mode Balance Video Quality and Power Savings
Power Policy:Power Plan Personality (Plugged In)
The personality of the current power plan when the system is plugged in.
Power Policy:Video quality (Plugged In)
Quality Mode Optimize for Video Quality
System Availability Requests:Analysis Success
Analysis was successful. No energy efficiency problems were found. No information was returned.
Battery:Battery Information
Battery ID41167COMPAL PA3817U-1BRSManufacturerCOMPAL Serial Number41167ChemistryLi-ILong Term1Design Capacity48840Last Full Charge41792
Platform Power Management Capabilities:Supported Sleep States
Sleep states allow the computer to enter low-power modes after a period of inactivity. The S3 sleep state is the default sleep state for Windows platforms. The S3 sleep state consumes only enough power to preserve memory contents and allow the computer to resume working quickly. Very few platforms support the S1 or S2 Sleep states.
S1 Sleep SupportedfalseS2 Sleep SupportedfalseS3 Sleep SupportedtrueS4 Sleep Supportedtrue
Platform Power Management Capabilities:Adaptive Display Brightness is supported.
This computer enables Windows to automatically control the brightness of the integrated display.
Platform Power Management Capabilities:Processor Power Management Capabilities
Effective processor power management enables the computer to automatically balance performance and energy consumption.
Group0Index0Idle (C) State Count2Performance (P) State Count13Throttle (T) State Count0
Group0Index1Idle (C) State Count2Performance (P) State Count13Throttle (T) State Count0
Group0Index2Idle (C) State Count2Performance (P) State Count13Throttle (T) State Count0
Group0Index3Idle (C) State Count2Performance (P) State Count13Throttle (T) State Count0
