OK cheers. It's a fairly old machine, so if the fan and fins are clean and I don't find other reasons for overheating (and it continues) I guess it'll be worth refitting the heat sink.
OK, this is it:
Code:Diagnostic Report (1.9.0027.0): ----------------------------------------- Windows Validation Data--> Validation Code: 0 Cached Online Validation Code: 0x0 Windows Product Key: *****-*****-Q69TJ-G3YBJ-KW8XW Windows Product Key Hash: cQJO3zIxtDOCeiJ5+AhFZ+JYlRM= Windows Product ID: 00359-114-4402047-85599 Windows Product ID Type: 5 Windows License Type: Retail Windows OS version: 6.1.7601.2.00010300.1.0.003 ID: {60B857E6-E192-4AB7-B579-3049235DA3A7}(3) Is Admin: Yes TestCab: 0x0 LegitcheckControl ActiveX: N/A, hr = 0x80070002 Signed By: N/A, hr = 0x80070002 Product Name: Windows 7 Home Premium Architecture: 0x00000009 Build lab: 7601.win7sp1_ldr_escrow.191127-1706 TTS Error: Validation Diagnostic: Resolution Status: N/A Vista WgaER Data--> ThreatID(s): N/A, hr = 0x80070002 Version: N/A, hr = 0x80070002 Windows XP Notifications Data--> Cached Result: N/A, hr = 0x80070002 File Exists: No Version: N/A, hr = 0x80070002 WgaTray.exe Signed By: N/A, hr = 0x80070002 WgaLogon.dll Signed By: N/A, hr = 0x80070002 OGA Notifications Data--> Cached Result: N/A, hr = 0x80070002 Version: N/A, hr = 0x80070002 OGAExec.exe Signed By: N/A, hr = 0x80070002 OGAAddin.dll Signed By: N/A, hr = 0x80070002 OGA Data--> Office Status: 109 N/A OGA Version: N/A, 0x80070002 Signed By: N/A, hr = 0x80070002 Office Diagnostics: 025D1FF3-364-80041010_025D1FF3-229-80041010_025D1FF3-230-1_025D1FF3-517- 80040154_025D1FF3-237-80040154_025D1FF3-238-2_025D1FF3-244-80070002_025D1FF3-258-3 Browser Data--> Proxy settings: N/A User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Win32) Default Browser: C:\Program Files (x86)\Mozilla Firefox\firefox.exe Download signed ActiveX controls: Prompt Download unsigned ActiveX controls: Disabled Run ActiveX controls and plug-ins: Allowed Initialize and script ActiveX controls not marked as safe: Disabled Allow scripting of Internet Explorer Webbrowser control: Disabled Active scripting: Allowed Script ActiveX controls marked as safe for scripting: Allowed File Scan Data--> Other data--> Office Details: <GenuineResults><MachineData><UGUID>{60B857E6-E192-4AB7-B579-3049235DA3A7} </UGUID><Version>1.9.0027.0</Version><OS>6.1.7601.2.00010300.1.0.003</OS><Architecture>x64</Archit ecture><PKey>*****-*****-*****-*****-KW8XW</PKey><PID>00359-114-4402047- 85599</PID><PIDType>5</PIDType><SID>S-1-5-21-2785788139-3172466215- 127188836</SID><SYSTEM><Manufacturer>TOSHIBA</Manufacturer><Model>Satellite C660</Model></SYSTEM><BIOS><Manufacturer>TOSHIBA</Manufacturer><Version>2.00</Version><SMBIOSVersi on major="2" minor="6"/><Date>20120509000000.000000+000</Date></BIOS><HWID>C9333107018400FC</HWID><UserLCID>080 9</UserLCID><SystemLCID>0409</SystemLCID><TimeZone>GMT Standard Time(GMT+00:00) </TimeZone><iJoin>0</iJoin><SBID><stat>3</stat><msppid></msppid><name></name><model></model></SBID ><OEM><OEMID>TOSCPL</OEMID><OEMTableID>TOSCPL00</OEMTableID></OEM><GANotification/></MachineData>< Software><Office><Result>109</Result><Products/><Applications/></Office></Software></GenuineResult s> Spsys.log Content: 0x80070002 Licensing Data--> Software licensing service version: 6.1.7601.17514 Name: Windows(R) 7, HomePremium edition Description: Windows Operating System - Windows(R) 7, RETAIL channel Activation ID: 2e7d060d-4714-40f2-9896-1e4f15b612ad Application ID: 55c92734-d682-4d71-983e-d6ec3f16059f Extended PID: 00359-00170-114-440204-00-2057-7601.0000-1042017 Installation ID: 014386144706755884486491910613241191577684835571405943 Processor Certificate URL: http://go.microsoft.com/fwlink/?LinkID=88338 Machine Certificate URL: http://go.microsoft.com/fwlink/?LinkID=88339 Use License URL: http://go.microsoft.com/fwlink/?LinkID=88341 Product Key Certificate URL: http://go.microsoft.com/fwlink/?LinkID=88340 Partial Product Key: KW8XW License Status: Licensed Remaining Windows rearm count: 3 Trusted time: 09/01/2020 15:07:41 Windows Activation Technologies--> HrOffline: 0x00000000 HrOnline: 0x00000000 HealthStatus: 0x0000000000000000 Event Time Stamp: 11:26:2019 13:32 ActiveX: Registered, Version: 7.1.7600.16395 Admin Service: Registered, Version: 7.1.7600.16395 HealthStatus Bitmask Output: HWID Data--> HWID Hash Current: MAAAAAEAAgABAAEAAAABAAAAAwABAAEAln2AHxKJpF+aUcgvemICWxivWESypVxd OEM Activation 1.0 Data--> N/A OEM Activation 2.0 Data--> BIOS valid for OA 2.0: yes Windows marker version: 0x20001 OEMID and OEMTableID Consistent: yes BIOS Information: ACPI Table Name OEMID Value OEMTableID Value APIC TOSCPL TOSCPL00 FACP TOSCPL TOSCPL00 HPET TOSCPL TOSCPL00 MCFG TOSCPL TOSCPL00 ASF! TOSCPL TOSCPL00 SLIC TOSCPL TOSCPL00 SSDT PmRef CpuPm UEFI PTL PTLBUFýç UEFI PTL PTLBUFýç UEFI PTL PTLBUFýçThanks, I'll have a Toshiba purge! Good point about them not updating, which may be a security concern - and I didn't know that about Dynabook. I'll check it out.There's no real reason to keep any of the Toshiba stuff, W7 has all the same programs/options built-in
(they wont be updating anything anyway - back-up support now provided by Dynabook)
It says something went wrong. Tried a couple of times. Since it doesn't say what, it's hard to know what to look for in the forums, etc. Possibly legacy hardware or something. I could maybe contact them.general
Install Intel's driver checker, only once check/update as required then remove
https://downloadmirror.intel.com/284...-Installer.exe
I use Sleep every day, and Hibernate is useful as a setting for low battery power. I don't really understand the latter. What are you thinking I should do with that setting?if you dont use sleep/hibernate
Hibernate - Enable or Disable
PCIe Link State Power Management - Turn On or Off in Windows
note you will need to change certain power options
Could you say more? Why do this (on SSD)? What does the 'before and after' give me?Run MS Disk clean-up tool if you've NEVER used it then it acts like a update install with a before and after operation hence could take a while
Drat, I just did that recently - I forgot you shouldn't defrag them. Good to have the reminder. Thanks.turn off disk defragment service, you have an SSD
I'll look into that. Brownie points always useful.Use Macrium free as a back-up, and on the Wife's if you need Brownie points
Cheers.There is tutorials sub forum here, just punch in what you want to know about
It has a card reader device, yes. I'm not sure if there's anything at all wrong with it, but I thought it was odd that the drive appears in file browsers (I've a few) even when there's no card in it (removed safely). However, it didn't require safe removal, I noticed - the Safely Remove... icon doesn't show up with it and - if it's the "Generic - Multi-card USB Device" listed under Disk drives in the device manager (selected in pic below), that requirement is set as <false> in the relevant Properties dialogue. Are you advising I disable it? Temporarily? What for? It its apparance in directory lists wrong, do you think? Thanks.
