Java Problem, Help Required!
  1. Posts : 2
    Having a problem with my java or try to put update 24 (32 bit on 64 bit system) on my Windows 7, Whenever i try to install it i get this message
    followed by
    Any ideas how to fix it?
  2. Posts : 5,092
    Windows 7 32 bit
    There may be a Java cleanup tool for download. I would make a restore point first so you can get Java back if something goes wrong. But I would think you'd be able to put the latest version on a clean system.
    IOW, install the latest "whole enchilada" instead of an update.
  3. Posts : 2
    How do i do that mate?
  4. Posts : 5,092
    Windows 7 32 bit
    Search the Java download site for Cleanup or Removal tool. Remove java. Install the entire latest version.
    I'm sure there's instructions written by them as it's their software.
  5. Posts : 2,039
    Several, including Windows 7 x64 Ultimate
    followed by
    Run this;
    http://raproducts.org/wordpress/software
    Regards....Mike Connor
