Windows 7: Help help help
03 Dec 2009   #1
BriniaSona
Help help help
Windows Live Messenger Error 40048820
I have tried:
Uninstalling msn and reinstalling
uninstalling with revo uninstaller and perfect uninstaller.
tried registering the .dll files.
MY F***ING CLOCK AND TIME is right.
i tried changing the proxy crap and internet settings relocation check server thing
I have tried hitting my computer with a hammer causing it to freeze and having to reset it and still NOTHING
HELP ME PLEASE i'm angry and emotional and if I had a Gundam i'm sure 1/4 of north america would have been decimated already.
03 Dec 2009   #2
Jonathan_King
Windows 7 Professional x64
See is there is anything in the link of use.
Windows Live Messenger problems? Here's a fix.
03 Dec 2009   #3
BriniaSona
That isn't there. I only see
perpassportsettings
retailzonelevels
retailzones
sqm
03 Dec 2009   #4
BriniaSona
please
04 Dec 2009   #5
BriniaSona
Sigh no one anywhere on any forum will help me
04 Dec 2009   #6
Jonathan_King
Apparently nobody here knows the answer. This is a Windows 7 forum, not an application-specific forum. True, there is a high probability someone here knows to answer to any given question, but I would recommend posting on a Microsoft forum, such as this.
04 Dec 2009   #7
Tews
64-bit Windows 8.1 Pro
There are other IM clients other than Messenger that you could use...
04 Dec 2009   #8
nate42nd
Windows Live products have their own hidden uninstaller and repair program. I am at work or I would tell you where it's hidden, but if you browse to (Just guessing) program files / Microsoft / Windows Live / it's called Wlarp.exe. If you run this it will give you the option to fix or un-install any Windows Live program. It might work for you.
Look for this file in the progams / Windows Live folder somewhere. If you can't find it, I will tell you where it is in about 10 hours.
04 Dec 2009   #9
BriniaSona
the Wlarp didn't work.
the msn guys spin. and then freeze up just as it would logging me on normally then it give me the error.
04 Dec 2009   #10
nate42nd
SO you tried repair and it didn't work. Well good luck. I hope someone can help.
 Help help help
