Audio problem
  1. Posts : 8
    Microsoft Windows 7 Ultimate 64bit
    Audio problem
    Hello all, my audio was working fine for a year, but a few days ago there was no sound, so I restarted my computer and the sound worked for 30 mins or so then went out.
    I checked to see my drivers were up to date and they were. So then I uninstalled the driver and tried to reinstall one from HP but I'm getting an error of cannot find media device etc.
    I believe the problem is windows 7 is not detecting my sound device at all therefore I cannot even install a driver for the sound device the pc does not know is even on there.
    I've tried to install UAA Bus Driver for High High definition audio, because I read this is required for the pc to detect the sound device in the first place, but i'm getting an "HPQNT.dll failed, reply was FALSE" error.
    no sound devices
    as you can see there is not "Sound, Video and game controllers" option under the Device Manager anymore.
    Also the same time the audio stopped working the HP Quickplay buttons on the keyboard also stopped functioning.
    HP dv6607nr Laptop
  2. Posts : 908
    Windows 7 Home Premium
    Did anything major change before this happened?
    Like a BIOS update or any major applications or games installed?
    Have you run a virus/Malware scan?
    One thing you can try... get into the BIOS, is the audio/sound option enabled?
    If so, disable it, reboot, after windows loads reboot again and enable audio in the BIOS, see if Windows picks it up on the next boot.
    Other options.. Could audio have been disabled in services?
    Services include both:
    Windows Audio
    Windows Audio Endpoint Builder
    Ap
  3. Posts : 8
    hmm thx for reply,
    I did install a new game PSO:BB and a week after that the sound problems came, also during this week I've been playing around with the mixer option in sound for the first time, because I wanted to mute the game's sound, I dunno if this contributes to anything.
    No recent BIOS Update.
    And I'm not sure how to check if the audio/sound is enabled in my BIOS, not seeing the option anywhere,
    I got phoenix BIOS, and it's up to date.
    Virus scan done, nothing.
    Audio services are auto and on.
  4. Posts : 8,608
    Windows 7 Ultimate 32bit SP1
    Did you go back and undo the things you tried above? You could also do a repair install.
  5. Posts : 8
    yes I've tried and nothing
  6. Posts : 842
    Windows 7 Ultimate 64 - OEM Service Pack 1
    I notice on your other devices there is a question mark there can you expand by clicking on the little arrow and post a screen shot please.
    Steve
  7. Posts : 8
    Also under "System Devices" there is no Microsoft UAA bus" w.e ... after I installed it in compatibility mode - vista sp2
  8. Posts : 8,608
    See if this method works No sound with Windows 7 64-bit.
  9. Posts : 8
    Ah i've alrdy came across this thread and tried, but no help
  10. Posts : 8,608
    Do you have external speakers to see if they will work?
