Windows 7: Audio problem in W7 (no sound)
04 Aug 2010   #11
MaoR
Quote   Quote: Originally Posted by Night Hawk View Post
Well you mentioned pressing "something" and then the sound started working which makes you wonder if a connection problem is present but being picked up more while booted in 7. That's when you saw the X disappear there.
The swap between speakers and then headphones would seem to point at a problem on the board possibly a contact arcing or a cold solder point picking up some IF which would account for the popping sounds you heard. When first starting up everything still needs to warm up where a cold solder point wouldn't have pushed anything away from the board until later.
You may have to consider a separate sound card if the onboard is the source. The mixer and volume controls are strictly software there depending on the hardware side.
Night Hawk, I didn't really understand what you were saying..What is the problem with my motherboard, and how can I fix it? have I broke something? is it unrepairable?
Quote   Quote: Originally Posted by Aphelion View Post
A lot of the recent machines, both laptop and desktop have multi-purpose audio ports. One thing I do now is take a stereo cord with a 3.5mm end (like headphones) and spray the metal end with a little contact cleaner then work it in and out of all the audio jacks. This helped my Gigabyte mainboard when putting this machine together, was getting erratic behavior before that.
Ap
Again, I didn't understand
I dont really care why this happend I just want to fix it (dont offend :))
Thank you for trying to help me.
I really thank you, and hope you will solve my problem.
04 Aug 2010   #12
Night Hawk
W7 Ultimate x64/W10 Pro x64 dual boot main build-remote pc W10 Pro x64 Insider Preview/W7 Pro x64
The first thing to note is hearing sound when booting into XP right away which shows you booted into the older version when? after the audio cord was plugged not while booted in XP. You did plug it in while booted in 7 however and while the system was powered up.
You never explained what you pressed on which sounds like the plug on the end of the cord being used.
As far as the board that would be a contact inside the audio stretched or a possible component lead soldered onto the board suddenly seeing a loose solder point. That's where some lead of a component and even the small amount of solder lifts away from the board itself even in a very tiny gap to break the connection and continiuty. But if you have booted into XP since and still have normal sound something like that would be ruled out.
You mentioned downloading another driver when that shouldn't have been necessary if you already had normal sound prior to plugging in the cord. One place to look would be the Sound, Video, abd game controllers section in the device manager just as a thought to see if any items are now yellow marked.
The process of elimination in case this and hopefully will turn out to be strictly software related as far as 7 is concerned since you are getting sound in XP. Likely it will turn out to be something small like a driver knocked out or made inactive somehow.
04 Aug 2010   #13
MaoR
Night Hawk, I am having trubble understanding what you say.. I guess your languange is too high..
I get what you say in parts, but can't really figure it out..
I dont get sound, not in W7 and not in XP.
In both operation systems I get a very low volume sound, and not a clear one..
I dont think it has something to do with the W7 settings as you said to go to "Sound, Video, abd game".
What do you mean?
I dont press anything.. just play a song or a movie, and can't really hear it.. very unclear and low sound.
In XP I have Realtek HD audio control panel, and when I plug the speakers to the green slot, it showed like I plugged it to the black one.
Tell me what else do you need to know for solving the problem.
If you could speak a bit more clearly (for me.. because I am having trubble understanding) and in steps, that would be great.
Thank you Night Hwak, and I am really sorry..
04 Aug 2010   #14
Night Hawk
Quote   Quote: Originally Posted by MaoR View Post
edit:
well, I pressed some connection inside the computer, near the plugs and switched to W7.
I dont have the red "X" near the speaker's icon anymore..
But my headphones and speakers make a horrible noisy sound..
I played a song and I really can hear it when I hear on maximum volume.. but the statitc sound or whatever that is, is so noisy..
What can it be?
What do you mean?
You mentioned earlier about pressing "some connection inside"? and then noticed the X was gone. Do you recall what you pressed while inside the case like a wire leading over to the optical drive or something going to the board directly?
This is what tends to point at that being a likely source of the low volume as well as previous noises being heard if you have only a partial connection. A single strand of wire making contact or perhaps one of the other possible items like either a cold solder point or bent contact inside the audio jack there.
Something barely making contact wouldn't allow enough current or signal strength resulting in a low volume as well those noises you had been hearing. If something is touching a ground source like a loose strand of wire that would pull things down as well.
Before you had mentioned having sound in XP but not 7 which would point at a software/driver type problem. But with both running into the same a close inspection and retracing of the steps you have taken there so far may reveal where the problem is.
05 Aug 2010   #15
MaoR
edit:
What can it be?
What do you mean?
I pressed some connections close to the audio jacks from inside the case.
I pressed them because mabey they got loose or something..
I didn't say I have sound on XP but not in W7, I meant that when the problem just started, I thought it's just something in W7, so I switched to XP, and saw that I dont have a red "X" near the speaker or something like that, and I could even go to "Windows Movie Maker" and play something in there (but with no sound.. in W7 I couldnt even enter WMK).
Is there something else you need to know? or I didn't say enough about something?
Thank you!
05 Aug 2010   #16
capricious
windows 7
movie-no audio
Hello!
I want to watch a movie on the HDTV from my laptop by connecting them together. I have a VGA cable and port for video connections however I receive no audio using the rca cable plugging it to the headphone jack.
I tried changing the default on 'sounds and devices'. doesnt work.
ive recently upgraded to windows 7 but i used to use vista and it worked perfectly.
can someone explain this to me? I cannot use the HDMI cable simply bcause my laptop doesnt have the port.
thank you in advance for any assistance
05 Aug 2010   #17
MaoR
Quote   Quote: Originally Posted by capricious View Post
Hello!
Open your own topic..
I got bigger problems..
05 Aug 2010   #18
Night Hawk
Agreed! no thread hijacking sorry!
As far as you pressing on things when inside the case that caused the thought of a possible cold solder point or loose contact when you suddenly saw the X disappear. Continuity was established with the loose contact or broken solder then making contact.The odd loud noises would be from the arcing of live current despite how small that is you then take a distorted signal and amplify it through the tv or your speakers becoming loud.
To really know for a certainty on that however you would have to get in there and possibly remove the board to go over it completely on top and bottom around the jacks closely examining the contact points on the bottom with a magnifying glass even to see if any of those points had lifted away slightly from the board. Typically all the solder points from the different jacks are grouped together on the underside.
If this is from a contact inside the jack being used... ouch! The only real way to solve this seems to be adding a separate card in especially if one of those problems are found. An experienced assembler could take care of a cold solder point however while a bad jack?
If this is a new board just in an rma would take care of the hardware side with a replacement. But for a board past dealer return/exchange you will likely end up having to go for the separate sound card.
05 Aug 2010   #19
bagavan
Windows 8 Professional x64
Try to reinstall the drivers and see if it works or not.
06 Aug 2010   #20
MaoR
Night Hawk, I am so sorry, but I cant understand what you are saying, can you please use more simple words?
Was it bad that I pressed the cable slots on the board (connections)?
What is a cold solder? I know what solder is, but what does it mean?
The "X" didn't suddenly disappear, I went to sleep at the night it happend, woke up in the morning and saw there is no "X".. a night after that I went to sleep again, woke up and heared a fainted voice, and without load noises.. and then nothing changed..
Thank you for helping
Problem with sound device with audio input.
I got a problem with my audio system. I have got two sound devices for my PC and one of them is not working. I have got one Philips Subwoofer which works fine, it has got a audio input. Also I have got a Philips Tv-flatscreen used as main monitor which is connected with a HDMI-cable. Ever since...
Windows 7 IDT Audio 5.1 Sound Problem.
Hi guys . 1 day ago i had a problem with my IDT audio on windows 7 . I couldn't set 5.1 option in the IDT Control Panel the setting jumped back to Stero options. I changed windows , changed alot of stuffs. I tried another way posted here that said to set 5.1 in windows control panel , this soultion...
SB Audigy 2 ZS Audio sound problem
i just installed win7 and i love it but sound sucks, i have SB Audigy 2 ZS Audio sound card, and i installed driver for it but my sound still sucks my problem is that i cant turn of 3D sound, i have stereo sennheiser headphones and when i play cod4 i only here on one speaker not the second one as...
Windows 7 problem not working of audio sound,no scf sca
I'v buyed Dell studio 1555 with Windows 7 Home Premium(64 bit).I had uninstalled power dvd(pre installed by Dell) using Revo uninstaller ,inadvertently I deleted some of the registry files. Now facing various problems... First there is no audio sound(no mp3,no login sound, no keypad sound..).. ...
General Discussion
sound/AUDIO problem on HP COMPAQ DC7100
Hey guys, I've installed Windows 7 and it really looks neat and fast, but I have one problem and it's getting my soundcard working. I've downloaded the vista drivers from HP from HP Compaq dc7100 Small Form Factor PC- Download drivers and software - HP Business Support Center Ive run...
