Audio problem in W7 (no sound)
Page 1 of 7 123 ... LastLast
  1. Posts : 42
    Hello,
    Two hours ago I plugged a sound wire from the PC to my LCD TV.
    And after I unplagged it I had some problems in my PC, I dont know why.. so I restarted. After the restart I had an icon of a speaker with a red "X" next to it..
    It sais " Audio output device is not installed"
    I dont know how that could happen.. I didn't change anything in the properties or something like that.. Just plugged a wire that splits to red and white to my LCD TV.
    When I try to watch a movie or listen to music in Windows Media Player, it sais it can't play because I have no sound intalled.
    I downloaded a sound driver for my motherboard and it didn't help
    I even tried to restore to 12 hours back, and it didn't help either.
    Please help me, I am hopeless..
  2. Posts : 13,354
    Windows 7 Professional x64
    Could something have gotten bumped a bit? Open up the case, and make sure all components, particularly the sound card, are seated firmly. It may help to unplug/disconnect them and plug them back in.
  3. Posts : 8,375
    Another place to go to is in the Control Panel>Playback tab to configure the output. If Windows refreshed itself to the default speakers the sound mixer would reflect that and see the output disabled.
    Typically you run into this type of problem with usb headsets as well where you then have to set them as the default in order to hear sound and not end up with it still coming from the speakers.
      My Computers
  4. Posts : 42
    I dont think the problem is in the settings.
    I have two operation systems (XP and W7), the problem happened in W7 so I switched to XP.. everything looks fine in XP, I can control the speaker volume and open Windows Media Player..
    But when I play a song or a movie, I still can't hear them..
    (I forgot to tell that when the speakers are plugged in they make a static like sound.. after the problem..)
    I can hear the song in very very low volume.. actually I can't really hear it, but I can tell something is playing..
    I tried plugging to the green port,black port and orange port, non of them works... And I tried with my headphones as well..
    Jonathan, I dont think I have a sound card, isn't it built on the motherboard?
    Night Hawk, Thank you, but I dont think it's something with the settings.
    Thank you for trying to help me :)
    edit:
    well, I pressed some connection inside the computer, near the plugs and switched to W7.
    I dont have the red "X" near the speaker's icon anymore..
    But my headphones and speakers make a horrible noisy sound..
    I played a song and I really can hear it when I hear on maximum volume.. but the statitc sound or whatever that is, is so noisy..
    What can it be?
  5. Posts : 8,375
    The sound mixer most likely. You can have the volume all the way up and all you will hear is static unless the signal is turned up as well. Sounds like something is still disabled there in the mixer like Auxillery.
    Attached Thumbnails Attached Thumbnails Audio problem in W7 (no sound)-sound-levels-mixer.jpg
      My Computers
  6. Posts : 42
    Thank you for the comment.
    I dont think it's something in the settings, I guess something messed up in the sound card it self..
    The sound isn't really static, it's a very noisy sound, like small pops.. hard to explain..
    It happens with my headphones too.
    When I plug my speakers to the green plug, the speakers make a loud noise like small quick pops, a bit like a static sound.. when I raise the volume to max, I can hear a game or a song or whatever.. but the pops are so loud..
    When I plug it to the orange plug, I dont hear anything (I heared when I plugged my speakers there before the problem..)
    Mabey something broke inside my PC?
    I think that is the most weird problem I ever saw.. (or heared..)
  7. Posts : 8,375
    When plugging speakers in while powered up you will always tend to hear something right off namely the instant contact with the live signal which tends to overload for a brief second the processing of the signal suddenly being input. This is seen with any type of audio input into amplification.
    The second orange jack will depend on the speaker settings more then anything if the jack is in good shape. There's no signal being sent out if the sound mixer/speaker settings are set for headphones or stereo. When switching to 2 1/2, 4, 5.1, or 7.1 surround then you should hear something maybe not as loud from the rear or center mix jack.
      My Computers
  8. Posts : 42
    Night Hawk, I know..
    But the sounds I got arn't normal.. I never had them..
    Now I started my PC, and there are no loud noises, but if I play a song, I hear it, but again.. it sounds like in very low volume.. althou the sound is on max.
    Thank you for your comment.
  9. Posts : 8,375
    Well you mentioned pressing "something" and then the sound started working which makes you wonder if a connection problem is present but being picked up more while booted in 7. That's when you saw the X disappear there.
    The swap between speakers and then headphones would seem to point at a problem on the board possibly a contact arcing or a cold solder point picking up some IF which would account for the popping sounds you heard. When first starting up everything still needs to warm up where a cold solder point wouldn't have pushed anything away from the board until later.
    You may have to consider a separate sound card if the onboard is the source. The mixer and volume controls are strictly software there depending on the hardware side.
      My Computers
  10. Posts : 908
    Windows 7 Home Premium
    A lot of the recent machines, both laptop and desktop have multi-purpose audio ports. One thing I do now is take a stereo cord with a 3.5mm end (like headphones) and spray the metal end with a little contact cleaner then work it in and out of all the audio jacks. This helped my Gigabyte mainboard when putting this machine together, was getting erratic behavior before that.
    Ap
