#21
When you look at any circuit board such as the main board itself noting the underside you will see the numerous solder points where leads for the various components are soldered to the traceways. They appear as small pinpoints of solder.
A cold solder point is where the sodering job failed or where the solder broke and the tip of the lead will move slightly upward through the small hole in the board itself. As the broken solder lightly touches the surface the electrical current we call the signal will arc. On a high voltage system you would see sparks when that happens.
Ever jump start an auto? When touching the grips to the terminal poles on the battery sparks may fly. On a low voltage audio circuit strange poping, humming, buzzing sounds would be the thing you would hear there.
Likewise when looking at where the contact leads go through the preformed hole on a main board from the rear jacks those will be small solder points too. When you mentioned pressing down and suddenly hearing sound the movement of a possibly broken solder point made contact likely as soon as you lifted your fingers away the audio lead sprung back enough.
The odd sounds and low volume may have causeanother as well if the audio chip on the board has failed. Since the problem is effecting both XP and 7 you now have to consider it a hardware fault of some type. Due to the arcing if something was bumping against a ground source the audio chip may have been damaged from that or have simply been slightly defective to start with now revealing itself.
One reason for suggesting a separate sound card would be to see the onboard disabled and then find out if the audio is heard normally through the tv or speaker set in use. Since you patched directly to the tv you should then hear the normal output.
For examination of the leads on the board on the other hand that would require removing the board and a very close examination of the area where the contact points are grouped since it would take that to see only the slightest lift up of the short leads soldered there.
As you can see it does get quite involved in order to trace each possible cause. You could end up taking the board out entirely to perform a close examination only to learn it was the audio chip or problem with the audio jack itself needing replacement.
If you were formally trained in electronics I could advise scoping the board or performing a continuity test on each lead for tracing purposes. But you would need to remove the board entirely for continuity testing each solder point if the case blocks access to the underside of the board itself using a multimeter. A 1/8" miniplug would be plugged into each jack with a short length of wire with the ends exposed for keeping one tip from the meter held against each as you go along while touching the other lead lightly on each solder point until hearing a long beep sound from the meter.
You would however might need the schematic for the board to know which wire went to which solder point on the board since those are all covered over with the silver colored enclosures typically seen.
To keep this from becoming a separate course in length I would simply advise at this point going with a separate sound card assuming the problem is on the board. The X vanishing does show that 7 as well as XP was detecting the audio and loading the drivers as it should but the problem with something hardware related is preventing the normal audio you expect.
If you unplug the audio cord going to the tv and plug in a speaker set which suddenly works well then you would know the problem was external. Your description however tends to suggest a board or contact in the audio jack type of problem.
If a separate speaker set on the other hand hears normal sound when using the onboard then the output signal would be found incompatible with the input on the tv there. This would be the quick test to see if the problem is localized to the board that can be looked at before simply electing to go for a separate card.
