No Sound, Tried Everything, Please Help!
Page 2 of 4 FirstFirst 1234 LastLast
  1. Posts : 17
    Windows 7 Home Premium 64-Bit
    Jacee said:
    Are your drivers and Windows updates all up to date?
    Run a PC Pitstop test PC Pitstop TechExpress (Overdrive/full test)
    When the test has finished, copy the results from the address bar and paste them back here ... we might be able to trouble shoot from the test.
    This is what will appear in the address bar, but your's will have different numbers
    PC Pitstop OverDrive Tests Overview
    Here.
  2. Posts : 17
       #12
    Aphelion said:
    Jacee said:
    From the control panel, click on the sound icon. Now click on on the speakers icon > click 'properties', then the advanced tab. Set the dropdown button to CD quality and test
    Ok, try this... there are several places to access levels in W7, right click the Microsoft speaker icon in the task bar, select playback devices, single left click "speakers" then select the properties button at the lower right. Go to the Levels Tab, make sure they're all unmuted then raise the level on all of them, see if that gets you more volume.
    Ap
    The volume is already turned up all the way for speakers and headphones. Nothing was lower than 100 or muted.
  3. Posts : 8,608
    Windows 7 Ultimate 32bit SP1
    I don't see an anti-virus program running ... Microsoft Security Essentials is free. Download, update and scan http://www.microsoft.com/security_essentials/
  4. Posts : 17
       #14
    The Norton disc is at work, I'm going to install it later. But I'll see if MSE detects anything. Also, I had that before, but had to uninstall it because of some kind of problem...
  5. Posts : 9,582
    Windows 8.1 Pro RTM x64
       #15
    Have you updated the audio driver? The latest version is R2.51. See Latest Realtek HD Audio Driver Version To install, follow my Tutorial here: Device Manager - Install Driver - Vista Forums
  6. Posts : 17
       #16
    Yeah, tried that a couple times, just did it two minutes ago, still the same problem.
  7. Posts : 8,608
       #17
    [QUOTE=MaHiRzDaMaN;878503]
    What kind of problem did you have with MSE? Do you have all Windows updates?
  8. Posts : 9,582
       #18
    Just a thought. Have you checked Loudness Equalization in the Sound Effects tab of the Realtek HD Audio Manager?
  9. Posts : 17
       #19
    [QUOTE=Jacee;878523]
    I don't remember, it was when it first came out.
  10. Posts : 17
       #20
    Yes, it's checked.
