Windows 7: No Sound, Tried Everything, Please Help!
13 Aug 2010   #31
MaHiRzDaMaN
Windows 7 Home Premium 64-Bit
Quote   Quote: Originally Posted by Wheels of fire View Post
I have read through all your posts again and you say near the begining that it did work with windows 7. As you have reinstalled the drivers and even windows you should have all the default settings. From a software point I can't think of anything else to try. Just one thought though. Did you upgrade from an hp provided version of Vista ? If so then Windows 7 may have taken some settings from there that have now been lost. Fancy a reinstall of vista to check ?
I didn't upgrade from Vista. I had the Windows 7 beta before.
13 Aug 2010   #32
MaHiRzDaMaN
Quote   Quote: Originally Posted by gregrocker View Post
Often times in cases like this it needs a bigger software package, or the software package installed is not exactly correct.
You referred repeatedly to "driver" but this is one of those devices that requires additional software. While it appears that you do have the Realtek, maybe you don't have the full package or don't have the exact one. Research to know for sure you have the fullest and correct software package.
I would also uninstall software cleanly in Control Panel or using Revo, including Sound driver(s) in Device manager, then reinstall the full software package thus making sure you are picking up its driver and not a lesser preliminary driver that came in installer or Updates.
I admit it is slim pickings, but that's what I'd do if I was there. Also Google sound + your model and read everything others have experienced as I've solved sound issues this way sometimes. You may have already had this solved if you had posted your model and sound device in title, or googled it thoroughly.
Tried all of this for the last couple days, still nothing.
16 Aug 2010   #33
denig
Quote   Quote: Originally Posted by MaHiRzDaMaN View Post
This was a clean Win7 install for me too. What is so hard to understand is how we can get sound out of these boxes. I would have wven put blame on the motherboards but I install an independant sound card, recongized by win7 and still no sound!!!
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
narrator no sound - and sound vbs file no sound
I tried this file on my other win 7 and it works fine , but I have no sound with this file . and narrator has no sound also .. system sounds and mp3 's / movies sound good ... Ideas . thanks
Missing Sound Video & Game Controller in Device Manager, no sound
Hi Its bit complicated.:D I have 5 year old Compaq Pressario V3611AU notebook with AMD Atholon X2 TK-55 processor. Was using Windows XP and everything working fine. Recently I upgraded RAM to 2GB & processor was changed to AMD Turion(tm) X2 TL-60 2.00Ghz. I installed windows 7 and everything...
