Windows 7: No Sound, Tried Everything, Please Help!
01 Aug 2010   #1
MaHiRzDaMaN
Windows 7 Home Premium 64-Bit
I've had no sound on my Windows 7 64 Bit Home Premium for a couple of weeks. I've tried many different solutions from multiple websites, but I still have no sound. The drivers are all working properly, but there's no sound from the external speakers that I plugged in, the integrated speakers in the monitor, or my headphones. The troubleshooter can't find anything, and I've even reinstalled Windows 7 just now, but there's still no sound. When I click the sound icon on the taskbar and change the volume, the green bar moves, but I still don't hear the beeps from my speakers. The sound used to work fine before, on Vista Home Premium 64 Bit, and Windows 7 Home Premium 64 Bit, but it suddenly stopped. What should I do?
01 Aug 2010   #2
freaky88
MS Windows 7 Home Premium 64-bit
are you on a laptop?
01 Aug 2010   #3
MaHiRzDaMaN
No, I'm on an HP a6667c desktop.
01 Aug 2010   #4
Aphelion
Right click the Microsoft speaker icon in the taskbar, select playback devices, what is set as your default output device. (it will have a green checkmark).
Ap
01 Aug 2010   #5
MaHiRzDaMaN
The default is 'Speakers. I have also tried 'Headphones' and 'Realtek Digital Output'. When I try to play music, 'Speakers' recognizes that it's playing, but I don't hear any sound.
02 Aug 2010   #6
MaHiRzDaMaN
UPDATE: I plugged the headphones in and tried to do a sound test and watch videos, but the volume is really really low. I had to have perfect silence to hear it. The volume is turned up all the way on my computer in the sound icon, so I don't know why the volume is really low. This probably happened with my speakers too, but it was too low to hear. I plugged the headphones into the audio inputs on the front and rear of the computer, and both had the same effect.
02 Aug 2010   #7
Jacee
Microsoft MVP
Windows 7 Ultimate 32bit SP1
From the control panel, click on the sound icon. Now click on on the speakers icon > click 'properties', then the advanced tab. Set the dropdown button to CD quality and test
02 Aug 2010   #8
MaHiRzDaMaN
Jacee, I did that with the headphones, and the volume is still really low. And I don't hear anything at all on the speakers, so that's probably even lower.
02 Aug 2010   #9
Jacee
Microsoft MVP
Are your drivers and Windows updates all up to date?
Run a PC Pitstop test PC Pitstop TechExpress (Overdrive/full test)
When the test has finished, copy the results from the address bar and paste them back here ... we might be able to trouble shoot from the test.
This is what will appear in the address bar, but your's will have different numbers
PC Pitstop OverDrive Tests Overview
02 Aug 2010   #10
Aphelion
Quote   Quote: Originally Posted by Jacee View Post
Ok, try this... there are several places to access levels in W7, right click the Microsoft speaker icon in the task bar, select playback devices, single left click "speakers" then select the properties button at the lower right. Go to the Levels Tab, make sure they're all unmuted then raise the level on all of them, see if that gets you more volume.
Ap
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
narrator no sound - and sound vbs file no sound
I tried this file on my other win 7 and it works fine , but I have no sound with this file . and narrator has no sound also .. system sounds and mp3 's / movies sound good ... Ideas . thanks
Missing Sound Video & Game Controller in Device Manager, no sound
Hi Its bit complicated.:D I have 5 year old Compaq Pressario V3611AU notebook with AMD Atholon X2 TK-55 processor. Was using Windows XP and everything working fine. Recently I upgraded RAM to 2GB & processor was changed to AMD Turion(tm) X2 TL-60 2.00Ghz. I installed windows 7 and everything...
