If you're using Realtek Audio Manager [located in the Notification Icon Tray] you can search for Volume Control and scroll through till you find Adobe Flash Player. Make sure that sound is all the way up.
Adobe Flash player is the way to view videos on youtube, etc. And your games don't use Adobe Flash player.
Hope this helps someone even though the thread is really old!
