guess i won't save my 4.1 speakers ;(
apollo, your link doesn't show up the drivers you mentioned, where i can get it?
click agree and download will start
----------------------------------------------Below is for the listings if downoad does not work
Here and goto soundblaster audigy and then once there at driver listings got bottom you will see choose windows version select yours. also Vista ones also work
sorry to bother you again, but theres lot of versions of Soundblaster Audigy, what should i pick?
sorry, my bad, ive seen it :) i will test, i've downloaded SBAX_PCDRV_LB_2_18_0017.exe.
thanks, ill reply later
"Setup is unable to detect a supported product on yoursystem.Please
ensure that your product is properly installed before running this setup
program.
Setup will now exit."
hold the horses, open some champagne...! suddenly i dont know how my four speakers came alive after kxdvrv3550-86x-full.exe on win7... i installed this before and they didnt work... now they work...almost year after....
FINALLY!!
"im so happy... cause today i found...
THE SOLUTION OF THE PROBLEM!"
really thanks for the tips and help!
Congrats on the find i was about to say extract files from exe with winrar and manually load files via Hardware manager or put in system folders
